Okay so I just purchased a Castle SV2 sidewinder and 4 pole 4600KV motor, will be getting a new 2.4 radio, lipo and charger in the near future. Any recomendations on what pinion gear to use? I believe it came with an 81t spur, should I be changing the spur as well? I have also read about updating the slipper to a b4 slipper? Is that necessary? if so why is it better?
Regards,
Ren
Getting my B3 up to date
Re: Getting my B3 up to date
I'd prob start out with a 18T spur gear and watch your engine temps. If they are low, set it up a few teeth on the pinion, if hot drop it down a few. You can run the stock slipper, but the B4.1 clutch setup will make it more consistent and easier to adjust. I'd try what you have, see how it works and go from there.
NEW: SC10 4x4 FT, SC10 FT, (2)T4.1 FT, B4.1 World
OLD RC10's: (4)Worlds, Graphite Team Car, (2)RPM Ultra's, Tekin, B2 Team Car, B3, (3)Champ Editions, Team Car, (2)RC10T Team Truck
Tamiya: Hornet, Fox
Bolink: Invader
Losi: (2)XX, Junior 2, JRX Pro SE
Tamiya: Hornet, Fox
Bolink: Invader
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
I agree with above - 18 tooth is a good start.
I use a 21 tooth with a 3900kV motor and I wouldn't go any higher (motor gets pretty warm... although ambient temperatures are also pretty warm down here in South Texas).
I also use the stock B3 slipper, it works fine for everything except very high-end racing applications.
-dldiaz
- 27 Replies
- 2385 Views
Last post by Halgar
- 1739 Views
Last post by drc35ca
- 2747 Views
Last post by RC10th
- 1226 Views
Last post by Erich Reichert
- 1044 Views
Last post by David H
- 1041 Views
Last post by cas22
- 323 Views
Last post by kandkhobby13
- 3546 Views
Last post by mark in wi
Google [Bot] and 14 guests
