new to the forum need some info to race my gold tub
Its great to be a part of the forum now. I am currently racing my gold tub for fun I seem to have most of it dialed. My issue is the stock shocks what are you guys running for shocks/towers etc. I am running 2.2 wheels. Ill post up some pics soon
- RC104ever
Re: new to the forum need some info to race my gold tub
There might be some answers here:
http://www.rc10talk.com/viewtopic.php?f=40&t=24904
I'm running modern v2 threaded shocks.
- Chris
Lots of cars...so many cars
I've got rpm arms front and rear on my buggy with fiberlyte shock towers what length shocks would work with the setup. I'm going to get the v2 shocks from tower
hello,
I try to mount big bore.
It is equipped with the photos I post.
Rc 10 1985
B4.1
TC 02C
TF5
B4.1
TC 02C
TF5
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
250r...standard shock sizes are 1.32 rear with 1.02 shafts and .71 fronts with .71 shafts. Modern V2s arent in those sizes, you need modified towers to run the B4 (or 4.1) shocks, 1.18 rear and .89 front.
lancia, I ran big bores for a while, they felt really good, but not better than the stock gold shocks (or I am such a poor driver I cant tell the difference)
Yes, I am running the modified towers I purchased from RC Carbon Works (now, not in those pictures).
Thanks for the info I don't mind spending a little money if it makes it a better car. I will look into the towers and get a set likely thanks for the size info also
Looks like the towers are out of stock. I will get the shocks coming now and get the towers when available.I like the rear tower with b4 wing mount holes:
Just bought brand new v2 shocks 34.99 a set eBay what springs are you guys running?
then I see a picture of your system spoiler?JK Racing wrote:250r...standard shock sizes are 1.32 rear with 1.02 shafts and .71 fronts with .71 shafts. Modern V2s arent in those sizes, you need modified towers to run the B4 (or 4.1) shocks, 1.18 rear and .89 front.
Have you made a hole in the bodywork?
Rc 10 1985
B4.1
TC 02C
TF5
B4.1
TC 02C
TF5
He may have used losi xx4 or kyosho zx5 rear wing mounts. they would bolt flat to a shock tower.
http://www.amainhobbies.com/product_info.php/cPath/1_25_1451_677/products_id/15199/n/Losi-Wing-Mount-Set-XX-4
http://www.amainhobbies.com/product_info.php/cPath/1_25_1460_232/products_id/5121/n/Kyosho-Bumper-Wing-Stay-Set-ZX-5
- JK Racing
Those are B4 wing mounts, bolted to the RC Carbon Works towers, they already have holes in them for that. Yes, I cut a square out of the back of the body to let the mounts through. The wing in J Concepts high downforce/high clearance wing, I think 6.5 inch. Its pretty big, I cut almost all the wicker off to tame it down.
- JK Racing
Missed the springs question, I use black up front, green in the rear. Probably good to get a set of brown for the front as well (I think that is the spring that comes with the shock kit). Others may chime in on rear springs.250r wrote:Just bought brand new v2 shocks 34.99 a set eBay what springs are you guys running?
Check here for racing set up discussions and post questions as needed:
http://www.rc10talk.com/viewtopic.php?f=38&t=27135
Thanks for the help bro. I ended up getting both front and rear spring kits also. I got the front tower ordered the rear says out of stock I'm going to call.them Monday am. Thanks again
- 1210 Views
Last post by treehugger
- 20 Replies
- 5752 Views
Last post by R Cane
- 474 Views
Last post by Andybellus
- 2081 Views
Last post by Brat
- 1411 Views
Last post by mtbnjim
- 1418 Views
Last post by pejota
- 22 Replies
- 4047 Views
Last post by RC Chick
- 914 Views
Last post by civilguy
howsyouraspen and 5 guests
