Since my associated shock rebuild debacle a few months ago I decided to use Kyosho Velvets for my old is new build rc10 goldpan. I have a 10T rear tower and I think rpm worlds front tower where the nose tubes go through, both are fibre lyte. The velvets are in mm but I wasnt sure if all other measurement aspects were the same, ie do I need exactly the same mm velvets that equate to 1.02" associated front shocks?
Any help is appreciated, thanks. I am using Dynotech front and rear arms, btw.
Which kyosho velvets for old is new?
- flipwils11
- Been thanked: 19 times
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
Re: Which kyosho velvets for old is new?
I cannot answer your specific question, but, maybe this will help:
I have an OIN with Associated Wide Track front A-arms and Atlas "Worlds" front shock tower - I believe the Associated shock for this setup is the 0.71,
I use 30mm Kyosho Velvets, they fit perfect.
The rear has Associated A-arms with an Atlas "Worlds" tower - which I believe would use a 1.02 shock, now using 38mm Kyosho Velvets (also perfect fit).
-dldiaz
- flipwils11
Thanks so I wonder if it should be 38mm front and 46m rear?
- 2799 Views
Last post by Mr. ED
- 2844 Views
Last post by turbo_bird
- 710 Views
Last post by Asso_man!
- 389 Views
Last post by Dangeruss
- 1971 Views
Last post by bdrmbully
- 1646 Views
Last post by Mr. ED
- 3325 Views
Last post by rccars4sal
- 39 Replies
- 9681 Views
Last post by Mr. ED
