Track set-up
Track set-up
So I took my OIN RC10 graphite team car to the track to see how it would fair and Wow! First off, it was way harder than I remember keeping it where i wanted it to go, second I beat the living s&%t out of it. I though maybe we could use this post for guys who take there vintage cars to the track and give a desciption of the track and what tires/gears/suspension set-up,etc.. works. The track I went to was an indoor dirt short track with some good sized double and triple jumps (rcexitement in fitchburg Ma.) The surface is very hard almost like concrete with some loose dirt thrown on top. I was geared 73/32 with a 3900kva Reeady motor and a 5000mah LiPo. I couldnt use half the power I had so I'm thinking some lower gears would work better. What do you guys run for gears on short dirt tracks? I had some soft compound dirt oval tires that seems O.K. but I think I need something with a bit more bite. I'll be upgrading to 2.2 rims soon and I was told barcodes in blue are the best there. I also noticed I was bottoming out pretty regularly if I didn't hit the jumps just right, what springs are you guys running on your cars that see some air time? Here is a pick after an hour on the track. The antenna tube broke off, the bumper bent in, and the wing wouldn't stay in at all, and I popped one ball cup and one axle....but I'm hooked!
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: Track set-up
Sounds fun.MattyCJ7 wrote:The surface is very hard almost like concrete with some loose dirt thrown on top. I was geared 73/32 with a 3900kva Reeady motor and a 5000mah LiPo. I couldnt use half the power I had so I'm thinking some lower gears would work better.
Re: Track set-up
http://www.rcexcitement.com/tracks.html#
apparently the change the track very frequently. I looked on youtube and every video had the track in a different config. I dont know how they get the surface so hard, it's literally like concrete.
- civilguy
- Has thanked: 5 times
- Been thanked: 14 times
Re: Track set-up
Matty- there are a couple members here who run at RCE. Hopefully one of them will chime in and give you some input on setup/gearing. Good luck to you and nice to see someone else who likes to run their RC10!
Jeff
Jeff
Re: Track set-up
Thanks. I can't wait to try the outdoor track when the weather gets better...restart learning curve!
- 2635 Views
Last post by CruzinCustomz
- 71 Replies
- 17989 Views
Last post by Headling
- 1511 Views
Last post by Seabass
- 53 Replies
- 10628 Views
Last post by Jeep-Power
- 930 Views
Last post by Fred19K
- 1902 Views
Last post by howaboutme
- 23 Replies
- 3598 Views
Last post by jcwrks
- 32 Replies
- 4831 Views
Last post by PlastiZapCA+
