RC10B4.1 Factory Team Worlds Kit by Slotcarrod
Forum rules
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
RC10B4.1 4.2 Factory Team Worlds Kit
I got two of these kits when they just came out, one as a runner and one for the shelf. Sadly had to retire the original B4 with all the FT options. I put all new parts on it and now it is a new shelf queen. I'm really looking forward to driving Associated new car, so lets begin.
The box is the same as the B4.1FT but has a Worlds label added to the top right hand corner.
slotcarrod
Re: RC10B4.1 Factory Team Worlds Kit by Slotcarrod
Front end is done, not much to it but disappointed that they don't use any carbon composite parts at all on this "FT" :roll: car!
Has thanked: 3699 times
Been thanked: 1980 times
The only thing that would be good about the RTR is not having to blister your thumbs putting turnbuckles together huh Rod? :( I hear ya on the CF, but at least they didn't use a "cab forward" body...
I've had the itch to build a new kit lately myself. Been a good while since I opened a sealed box full of parts. I'm jealous! :mrgreen:
slotcarrod
The worlds has the cab forward body! :lol:
Diamond Dave
Has thanked: 699 times
Been thanked: 130 times
Post by Diamond Dave »
I am looking forward to seeing this go together, Worth buying the kit then Rod?
slotcarrod
I think it's the best 2wd buggy you can buy!
Tranny and rear end done!
askbob
Post by askbob »
Lookin' good Rod! Been putting off getting one of the new kits for months now...
JHarris
Post by JHarris »
The carbon parts provide less traction.
Has thanked: 356 times
Been thanked: 470 times
JHarris wrote:The carbon parts provide less traction.
Associated buggies provide less steering, as I've learned. Nice to see the reuse of the worlds car though!!
slotcarrod
I can understand the arms, but can I use any carbon parts and not lose traction? Like towers and top plate?
Timmy2Tracks
Post by Timmy2Tracks »
I have been eyeing these for a while now. Nice to watch the build, thanks for posting it. I have not built a 2wd Buggy kit in, well, 25 years? Hehe...
What is the main chassis made from? Since it's black, it's hard to see in the pics. Fiberglass-y plastic?
slotcarrod
It's a composite but not carbon impregnated like the normal FT options! The carbon one would be lighter and stiffer!
Jeff will answer I'm sure, but I'm pretty sure they all lock the car up some. Per Jeff, when I narrowed the chassis and freed the parts up it became way more responsive.
JHarris
Post by JHarris »
In it's simplest form, flex = traction. You can use the carbon parts and save a little weight but you will be adding it right back in with sticky weights all over the place to get the car up to legal weight or to get it to handle right. The AE stuff is inexpensive enough that you could do your own experiment and run the car with all plastic parts then switch to the composite/carbon parts and see the difference. I will add that we just returned to the AE team and are working with Jason Ruona on getting our cars setup. I will be using a copy of his car as my starting point, which uses all plastic parts.
slotcarrod
Good to know Jeff!
I noticed that Ryan Maifield uses carbon front arms in this latest setup! http://www.teamassociated.com/pdf/cars_and_trucks/RC10B4.1/setup_sheets/B4_2012_Maifield_Clash.pdf .
