Blackfeet
Blackfeet
I used to have ( and will again shortly) an original blackfoot way back, but got out of the hobby before the other versions were out. I've seen the super, king,and extreme/III here n there-(dont care too much for the III myself) But i dont know how to tell a Super BF from a King BF. the pics i've seen appear to be the same. I know they changed the gearbox and put different suspension on the rear, but asside from the stickers on the bodies ( those with them), i cant tell the difference. Can someone help me out?
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Re: Blackfeet
Original blackfoot is frog based and used a ford 1980-1986 f150 step side
Super blackfoot used the orv frame but rear suspension and gearbox are different. Front suspension looks similar but uses longer front arms. Body same as original but with a billet grill and deleted ford emblem on tailgate
King blackfoot has SBF rear end but all new front suspension. The body is a 1992-1996 ford F150
Blackfoot extreme uses a wild dagger chassis.
Re: Blackfeet
thanks
I finally found some pics, if anyone else was wondering(these are pics i found, not my own)
here are the SBF front arms
here is the KBF
here is the KBF
- losiXXXman
- Been thanked: 5 times
Re: Blackfeet
I apologize if this is off topic, but was wondering... I had seen those other iterations of suspension, and thought
How about throwing that rear end (and front for that matter) on a frog. Seems like it'd be a cool setup for a classics/plastic chassis winner. No/Yes/ Maybe?
Re: Blackfeet
Crossed my mind as well. found this in an old thread, but i cant read it
but it looks totally bad a$$!
http://rcstreetsource.blogspot.com/2011/01/tamiya-frog-ta04-4wd-frog-awesomeness.html
- 2092 Views
Last post by hondaman
