My Blackfoot runner
markbt73
My Blackfoot runner
Post by markbt73 »
I snapped a couple photos of my favorite vintage backyard runner the other day and thought I'd share them. It's a Blackfoot, one of 2 that I got a few months ago in a trade deal. It has a bunch of period upgrades, including JG shock towers, CRP yellow front uprights, aluminum side guards (Parma maybe?), and Kyosho gold shocks in the rear and Duratrax golds in the front. Power comes from a standard 540, through a modern Dynamite ESC. The rear end is stock except for the "through-bolt" mod to hold the diff together; I've never had problems with the stock hex shafts on one of these trucks, at least with 540 motors, so I never bother to change them.
Anyway, on to the pics:
(this was supposed to be a wheelie pic, but the front wheels touched down just before the shutter closed)
4.whoa
Re: My Blackfoot runner
Post by 4.whoa »
Nice!! I just got one too, not here yet though :( dont do too many wheelies with that body, that rear panel is apparently hard to find :mrgreen:
markbt73
Post by markbt73 »
This body is trashed, so I'm not too worried about it. It's literally held together with hot glue and packing tape on the inside. If it gets too trashed, I'll pick up a Lexan shell for it.
This one, however, stays nice and pretty up on a shelf:
Mad Racer
Post by Mad Racer »
Love It.
Runners are great . All it needs is a decal ( Sorry sticker LOL) set.
Love the action shots.
squirrelnutz
Post by squirrelnutz »
Looks great! I have a couple of Blackfoots myself. I really like original tire pattern, but I don't like how rock hard they are. I know the re re bruiser has a bit softer tires now but is there any manufacturer that makes the same tires but in a softer more usable compound?
longboardnj
Post by longboardnj »
squirrelnutz wrote:Looks great! I have a couple of Blackfoots myself. I really like original tire pattern, but I don't like how rock hard they are. I know the re re bruiser has a bit softer tires now but is there any manufacturer that makes the same tires but in a softer more usable compound?
Blackfoots oe tires are best for blackfoots.. the hard tire will not get traction and it saves the trans/driveshafts. if you want to run different tires i say you get a rerelease frog trans/driveshafts
squirrelnutz
That makes alot of sense. I've heard alot about the frog dogbones popping out. Does this still happen when you use the cv boots?
markbt73
Post by markbt73 »
This particular one has Monster Beetle/Wild Dagger style tires on the rear. They hook up better on the grass. I've never had an issue with Blackfoot hex-end dogbones, only the diff gears. But keep in mind that no part of these trucks are really built for hot modern motors. You're better off going easy on the power, and getting something tougher (like a Stampede) for beating on.
longboardnj
squirrelnutz wrote:That makes alot of sense. I've heard alot about the frog dogbones popping out. Does this still happen when you use the cv boots?
lower the car a bit and its fine. i lower most my rcs(even if its just mounting the shock out 1 hole on the arm like on traxxas stuff ) . the driveshaft angles are too much on most rcs.
Return to “Tamiya Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 12 guests
