Futaba MC210CB esc keeps blowing fuse
Bought a small lot of futaba electronics lot off ebay. I was hoping that the esc would be the one thing to work but it does not. Every time the switch is turned on the led will come on and simultaneously the fuse will blow. Any ideas why? Took case apart and it looks clean, unburnt, doesn't smell.
Re: Futaba MC210CB esc keeps blowing fuse
Possible one of the fet's shorted? What the heatsink are on, use a multimeter to ohm out each device, may have to remove to test, if good sometimes the low voltage from the meter will turn on the fet's. Fets from others non working ESC may be compatible, check for cross reference. HTH.
- 19 Replies
- 4556 Views
Last post by Kobur
- 751 Views
Last post by AndrewSi
- 751 Views
Last post by GJW
- 1360 Views
Last post by Bormac
- 1412 Views
- 2707 Views
Last post by GJW
- 1297 Views
Last post by Brandon G
- 890 Views
Last post by juicedcoupe
Users browsing this forum: Google [Bot] and 2 guests
