What is the benefit of this BRP bearing crush sleeve?
camlchris
Post by camlchris »
What is the benefit of using this BRP bearing crush sleeve? How does it effect the performance of a pan car?
Has thanked: 3709 times
Been thanked: 1980 times
Re: What is the benefit of this BRP bearing crush sleeve?
I can't say 100%, but I would assume it's intent is to create a narrow surface for the inner bearing seal to seat against rather than being pushed against a flat block.
camlchris
Post by camlchris »
THEYTOOKMYTHUMB wrote:I can't say 100%, but I would assume it's intent is to create a narrow surface for the inner bearing seal to seat against rather than being pushed against a flat block.
NO, this is not the way it install.
Actually, it is install in between the two bearings of the rims. After installed, the front rim can "flex" left & right due to there is a small end-play. I will scan the manual here later.
Well it just goes to show that as usual I'm the Wikipedia of r/c. Lots of free information... most of it wrong! :lol:
camlchris
Post by camlchris »
here is the manual n & shape
Probably just scraps from another part they machined.
"Hmm, seems like a shame to just throw these out. I've got it! :idea: "
fakiee
Post by fakiee »
Sounds like a fancy definition for a spacer.
camlchris
Post by camlchris »
I hope Mr.Bud Barto can answer it.
camlchris wrote:I hope Mr.Bud Barto can answer it.
If he does see this I hope he knows my comment was in jest. That's my way of bowing out when I don't know what the hell I'm talking about (which is often). :oops: :lol:
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
The crush sleeve is used to prevent getting preload on the bearings by allowing the race to be the only part of the bearing coming into contact with the nut or whatever the tightening method is. This allows the ball bearings to rotate freely without any preload as I mentioned before which means less friction.
Also prervents sideload during cornering which would cause more pressure and friction on the ball bearings, the bearing turns freely even while cornering.
This is all very interesting!
camlchris
Post by camlchris »
a01butal wrote:The crush sleeve is used to prevent getting preload on the bearings by allowing the race to be the only part of the bearing coming into contact with the nut or whatever the tightening method is. This allows the ball bearings to rotate freely without any preload as I mentioned before which means less friction.
Thanks so much , my friend !
Users browsing this forum: User avatarRC10resto and 2 guests
