Kyosho Truimph Spur Gear ??????
- Mad Racer
I'm having trouble in locating a spur gear for my Truimph project.
Are there any other spurs that fit this chassis?
Or is there any after market spurs that will fit ?
Any help much appreciated.
Thanks
Mark
Thanks
Mark
- losiXXXman
- Been thanked: 5 times
Re: Kyosho Truimph Spur Gear ??????
Mark, some guys have sourced or made a metric to std bushing, and mounted std spurs, but I think you lose the slipper. Diggley's name comes to mind...
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Have You tried looking for a Lazer ZXR spurgear? The spur on my Triumph is the same as on the ZXR´s
Edit: I just checked the spare ones I have, the Lazer (LA2) is 0.6 module and the Triumph (TM7) is 48 pitch. Apart from that they share dimensions and adaption to the slipper.
Gone fishing
- Mr. ED
- Has thanked: 62 times
I believe I got an aftermarket one from liquidrc.com : 64dp. I don't remember the manufacturer but it's probably still bagged. I could look it up if 64dp is fine (no pun intended) for you.
- Been thanked: 10 times
The spur for the triumph is TM-7 100 tooth 48 p and yes the lazer spur also fit LA-2 but they are metric 0.5 or isit 0.6 module
the 100 tooth 48p can be ordered from www.rwracing.co.uk but you need ordinary associated hex pads instead of the red ones.
mvh Isobarik
mvh Isobarik
- Mad Racer
Thank you guys for all the replies . Much appreciated.
I was thinking of getting in touch with R.W racing. I bought one of his excellent Lazer spurs before & need another one.
Cheers
Mark
Cheers
Mark
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Mark,
Just recently unpacked my stuff, and thought I saw some NIP Triumph parts.... and yes, found a NIP TM-7 Spur Gear (100T-48P). Also found a TM-16 transmission housing, ('Axle Box' on the pack), if you're interested.
- Mad Racer
Alex you are a legend!!
PM Sent.
Thank You.
PM Sent.
Thank You.
Rw racing do a variety of spurs, i had one made identical to the lazer spur but without the little pole lumps, and also my updated spur for use with a b4 slipper clutch and another for use with the vts clutch.
- Mad Racer
Thanks Kyosho Fan.
Do you have his e mail address as the old e mail address I had from my last order bounced back.
Need to order another Lazer spur that you got him to make up.
Cheers
Mark
Cheers
Mark
[email protected] is his email and make sure you dont use caps as that may be why it didnt go through. Also as you know ive done a design with ball holes and B4 slipper pad hexes in one but have also done a deeper hex on either side without the ball holes so really down to preference. I did that to save space in what little spare room we have in the gear cover.Mad Racer wrote:Thanks Kyosho Fan.
Cheers
Mark
- 1357 Views
Last post by jackflak
- 2559 Views
Last post by JK Racing
- 802 Views
Last post by shredderboy
- 1119 Views
Last post by Chemical
- 773 Views
- 1218 Views
Last post by aconsola
- 736 Views
Last post by Qballll
- 920 Views
Last post by Phin
