Tire?
MattyCJ7
Tire?
Post by MattyCJ7 »
I'm rebuilding my 90 RC10 team car and I'm looking for advice on tires for hard surfaces (asphalt,packed dirt) that will fit on the original rims. Thanks
JK Racing
Has thanked: 140 times
Been thanked: 246 times
Re: Tire?
Post by JK Racing »
MattyCJ7 wrote:I'm looking for advice on tires for hard surfaces (asphalt,packed dirt)
This is easy, there are many current tires that could/will work..BUT
MattyCJ7 wrote:that will fit on the original rims. Thanks
Not for the original rims, that is the hard part. Asphalt only, check into the Custom Works tires, not sure how they would do on dirt (other than a nice clay oval :) )
MattyCJ7
Re: Tire?
Post by MattyCJ7 »
Their site is does'nt give musch ion the way of sizes or fitment. Does anybody know if any of their products will fit on an RC10
Phin
Has thanked: 87 times
Been thanked: 249 times
Re: Tire?
Post by Phin »
The CW tires should work on the rears but I don't believe the fronts will work.
A lot of people use the 2.1" spiked from Traxxas and the 2.0" step-pins from Losi on the old one-piece dish wheels but I don't know how those will run on your surfaces.
JK Racing
Re: Tire?
Post by JK Racing »
the CW rear tires are 2.0, tower hobbies has good sizing info:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRYG3&P=ML
the CW front tires are 2.0, tower again:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRYG2&P=7
they have rims as well, dont know if the rears work, but the fronts do
http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=custom+works+tire&search=Go
Has thanked: 365 times
Been thanked: 481 times
Re: Tire?
The fronts in the soft HB compound will stretch over the 2.1 rims, the rear wheels won't fit, but the tires sure do 8)
Phin
Re: Tire?
Post by Phin »
The CW front tires aren't too wide for the team car front wheels?
Re: Tire?
Phin wrote:The CW front tires aren't too wide for the team car front wheels?
Kinda, but just like installing current tires on the Duratrax Evader (B2 clones) the tire is wider than the rim, but as long as the bead is seated and glued the tire (with foam) will conform.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarBing [Bot], No User AvatarDotNetDotCom.org [Bot] and 4 guests
