I think the transmission is the problem cause the wheels are binding when I try to move it. Originally I thought it was the differentials til I pulled them apart for a rebuild, I eliminated the front differential cause I thought maybe that was the problem child and now the car will not move at all. I have a spare transmission I can try, has anyone else had a problem like this?
The rears spin free when the fronts are off the ground, and the fronts spin free when the rears are off the ground. The bind up when all 4 are on the ground.
trouble with mini lst
Forum rules
- Regular Member
- Regular Member
Re: trouble with mini lst
I was told that once before so I pulled it apart to find out, and found out they can only go in one way... If I were to flip them around the shock towers don't screw down right
Not the whole casing, can you not flip just the diff over in the case, I've have a few cars that have come my way that some ones done that to, last one being a Lazer zx5......
Front wheels went in reverse backs went forward, flip the front diff over, fixed!
- 5922 Views
Last post by joe sumasky
- 392 Views
Last post by fakiee
- 1627 Views
Last post by kaiser
- 692 Views
- 944 Views
Last post by Barnfind
- 1133 Views
Last post by Rustbucket
- 961 Views
Last post by Hanetrain
- 2408 Views
Last post by oldskoolracer
Users browsing this forum: Ahrefs [Bot] and 3 guests
