B4.5
Re: B4.5
Good luck on the track.
Javier -
- soniccj5
Re: B4.5
It looks cool I am sure there is a better explanation, maybe something about better balance or something.RichieRich wrote:Really cool. Remind me what the deal is with the narrow chassis that is so popular now?
- GreenHell
Re: B4.5
Track Report:
Well I made it to Trackside Raceway http://tracksideraceway.com/ in Brookfield, WI Friday night for a club race. With the Spektrum race coming the following weekend the place was packed. The surface is black dirt (with possibly some clay mixed in) slightly damp and high-bite. And the layout was simple but very fast with nothing too technical, think on-road with jumps.
Besides testing the new chassis I’m also working on a lightweight transmission setup for 17.5 stock (eliminated the slipper, 64p spur/pinion, aluminum top shaft and narrowed idler & diff gear). Throttle response feels more like a mild mod motor than a numb blinky-stock and carries more speed down straight as well, but I don’t think it will be effective in less than high-bite conditions without a slipper.
On to the chassis, besides getting lots of attention in the pit area it proved to be durable. In my first practice session I drove into the high-speed sweeper too hot, traction rolled, tumbled through the air and went into the boards without a scratch (was quite spectacular). I started with the same setup and tire combo I run with the +8 factory chassis. After I got the new track layout somewhat figured out and got comfortable, the car felt light and agile but the balance was off. The rear-end was locked down and the front pushed pretty hard on corner mid-to-exit, with the old car this was never a problem and I usually had to dial steering out. After trying a few different sets of tires and adding a little weight the car got better and as the race day progressed the track dried out slightly which also helped. Some how I managed to make it into the A-main and finished mid pack, pretty decent for its first time out but still off pace. In hind sight I wish I made the car shorter (+8mm instead of +10mm) and didn’t limit myself to a shorty pack in the far forward position (see version 2.0). I still plan on using it at the upcoming Spektrum race and am confident I can get it to work as good as the factory chassis.
Re: B4.5
That facility looks killer!
And the "speedy's" cut gears and the slipper eliminator is a great idea too!
My testing drove me to the conclusion that the chassis has to have a good amount of flex with the +10mm
- GreenHell
Re: B4.5
Torsionally the +10mm printed chassis feels similar to the +8mm AE. I made the battery box area extra thick and added a bulkhead behind the battery to tie it together. I’m thinking some of the balance issues the car has is because I moved too much weight forward and the car doesn't want to rotate, the added length doesn't help either.
Re: B4.5
I lost about 40% torsional rigidity when I narrowed the truck chassis, which really helped the initial turn in, and the length stabilized it after that-
- GreenHell
Re: B4.5
One thing I forgot to mention…
Some of the fastest most consistent buggies in the building Friday were mid-motor Centro C4.2 converted B4s, even after the track dried out some they still looked planted. I’m afraid most of this work was for nothing.
Re: B4.5
Added some droop to both ends to compensate for the extra chassis movement, kept all the ballast weight the same except the front end, where I increased it to 3/4 ozGreenHell wrote:Did you change your setup much from the B4 to the narrowed T4 chassis?
I'm ready to see a direct drive 17.5 B4.2.....
Re: B4.5
That's nice, but have you thought about also running MIP's new 17.5 Pucks system for even less rotating mass. I run those now and they have made a difference. I just picked up some of the Speedy diff and idler gears for my truck and buggy.
Javier -
Re: B4.5
I would love to see that and give it a try.I'm ready to see a direct drive 17.5 B4.2.....
Javier -
Re: B4.5
It's the only thing that hasn't come full circlejanaya wrote:I would love to see that and give it a try.I'm ready to see a direct drive 17.5 B4.2.....
