What outdrives fit a RPM 2.65 ?
OGRC10T
Post by OGRC10T »
I am rebuilding the trans on my rc10t...the bushings wiped all the shafts out...i decided to upgrade to the rpm 2.65 and avid bearings. I am trying to locate the stock 6577 and 6578 outdrives for the diff but I find that very little are available and the product is discontinued....my question is that I am wondering since the stealth trans came in multiple models is there different outdrives that will work for me or possibly a newer entire diff setup to swap in the rpm 2.65
I appericate any help or advice I can get
Fluorescent Green Tub RC10T 7011
RC10 Gold Pan Currently in rebuild http://www.rc10talk.com/viewtopic.php?f=35&t=28082
HPI RS4 Pro2
HPI RS4 Pro2 Rally
RC12R5.1 for Sale http://www.rc10talk.com/viewtopic.php?f=6&t=28260
Has thanked: 356 times
Been thanked: 470 times
Re: What outdrives fit a RPM 2.65 ?
Stock 2.25 outdrives and diff only. Try Customworks RC or Dynotech racing, they both had Customworks 2.25 (stealth copies) left and rights last time I looked.
Quikenuff
Post by Quikenuff »
Does anyone know if this an original stealth compatable kit? http://www.teamassociated.com/parts/details/7678/
Tower still carries this kit I think, when I was searching for out drives I found this, but never ordered them because I wasn't sure.
Quik
describes the application in the description, which unfortunately, does not include the original stealth ratio of 2.25. the diff gear, diff rings, outdrives are all too large.
OGRC10T
Post by OGRC10T »
Charlie don't surf wrote:Stock 2.25 outdrives and diff only. Try Customworks RCor Dynotech racing, they both had Customworks 2.25 (stealth copies) left and rights last time I looked.
Thanks for the info, I checked both sites but didn't see any...at least I know the stock 6577 and 6578 outdrives are the only ones I can get
HPI RS4 Pro2
HPI RS4 Pro2 Rally
Quikenuff
Post by Quikenuff »
jwscab wrote:describes the application in the description, which unfortunately, does not include the original stealth ratio of 2.25. the diff gear, diff rings, outdrives are all too large.
Thanks for explaining, Now I see. The bearings for the hubs may be the same but diff rings are larger.
I'll get you the pages I found them in-
OGRC10T
Post by OGRC10T »
Hey Charlie any luck in finding where you found those outdrives ? I missed out on a set on ebay and still searching, I got all my 2.65 case and avid bearings all ready to go just cant seem to find these dumb outdrives, i definitly dont wanna put my olds ones back in because the bushing worn into the metal alot
HPI RS4 Pro2
HPI RS4 Pro2 Rally
OGRC10T
Post by OGRC10T »
Found two similiar looking outdrives on their site but the description doesnt really help much...are these the ones that you saw?
http://www.customworksrc.com/ProductDetail.jsp?LISTID=80000457-1200011261
http://www.customworksrc.com/ProductDetail.jsp?LISTID=80000456-1200011261
HPI RS4 Pro2
HPI RS4 Pro2 Rally
RC104ever
Post by RC104ever »
Omg if those fit I'm ordering some right now.
- Chris
Lots of cars...so many cars
OGRC10T
Post by OGRC10T »
RC104ever wrote:Omg if those fit I'm ordering some right now.
Gonna call them tomorrow to see what they are for.
If not i am done looking...i am gonna use a mircometer and measure how much wear i actually got...anybody got a measurement for reference ?
Worst case they are going back in ...the wobble cant be that bad what will i lose 2 dollars in bearings ?
gotta drive the truck already
HPI RS4 Pro2
HPI RS4 Pro2 Rally
rctenracer
Been thanked: 81 times
Post by rctenracer »
OGRC10T wrote:Found two similiar looking outdrives on their site but the description doesnt really help much...are these the ones that you saw?
The rpm 2.65 comes with a top shaft and case. Use the stealth doner to complete. And yes the custom works are a dirrect fit. 4364 and 4365 are the correct ones. They are around 12 to 13 bucks each from tower.
bully
Been thanked: 6 times
Post by bully »
I thought they are for the 2.40 diff assembly when i was looking around everywhere for weeks, i was lucky to buy up some from dynotech b4 he sold out.
bully
Post by bully »
Anyone else confirm that these custom works outdrives are for the 2.25 stealth
rctenracer
Upate . The 4364 and 4365 custome works outdrives are the same size but will not accept the stealth 2.25 diff rings. They won't work.
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarGoogle Adsense [Bot] and 6 guests
