Fastcolor backing?
Fastcolor backing?
What are you guys using to back the water based Fastcolor? Does the Pactra laquer paint work as good as the Fastcolor backer?
Re: Fastcolor backing?
Backing color is normal the lights color used or white/silver. Black can also be used as a blacking, but this darkens the base coats. I would stick with water base paints for backing if you used them for painting of the body. Good luck post pictures!
Qballll
Qballll
- Been thanked: 325 times
I remember reading that you can spray Pactra-type paint over Faskolor but you have to give the water-based Faskolor plenty of time to dry & cure before painting over it with Pactra.
I'm not talking about what color to back the paint with. You have to seal the water based paint with something or else it will chip and degrade with water. I've used the fastkoat product they make and had good results. I'm currious if people use the laquer based paints for this purpose and had good results.
I haven't heard about needing to seal FasKolor paint...?
- Been thanked: 81 times
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
i use krylon clear coat, i can go look it up if you need.
- 1601 Views
Last post by justinspeed79
- 1228 Views
Last post by EM1-TC3
- 37 Replies
- 5769 Views
Last post by GreenBar0n
- 49 Replies
- 7866 Views
Last post by TRX-1-3
