2 wheel drive kyosho buggy....the name???
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
sorry no pic guy got it from said optima mid but its two wheel drive .Has a top plate over the steering bellcranks bolt passes through the top plate to chassis.Has yellow kyosho wheels and gold shocks.Has two 3 slot battery holder for 3 cells on each side.Black carbon shock towers.Not sure what i have but its kyosho lol.DON
Well i think maybe ultima pro XL BY LOOKN Ebay lol
DennisM
Has thanked: 30 times
Been thanked: 62 times
Re: 2 wheel drive kyosho buggy....the name???
Post by DennisM »
It could be a Ultima Pro XL.
If the rear arms are adjustable (toe-in), it´s either a Ultima Pro XL or a Triumph.
The triumph has a belt driven gearbox, topdeck from rear to front and uses 2,2 yellow plate rims.
It sounds interesting, a picture would be nice :D
Gone fishing
losiXXXman
Post by losiXXXman »
Does it look like the one halfway down this page Don? The US market Ultima Pro had a black fiberglass chassis instead of the pictured aluminum one. Those were European and Asian market.
http://www.rc10talk.com/viewtopic.php?f=30&t=25246
Mr. ED
Has thanked: 62 times
Post by Mr. ED »
Not a triumph: that car doesn't have the saddle pack cut outs mentioned.
Do, is the main chassis brownish alloy? ifso it's the european market ultima pro.
ifnot it could be the us version: check the rear arms as said above: xl has deep-reaching arms on both tranny and wheel side with ball ends at the wheel side.
THUNDERSTRIKE1
BLACK or grayish sandwhiched chassis light color in middle like sandwhich.Has adjustable almost in the wheels on rear arms.So i think its the ULTIMA PRO XL
its a nice car just needs tires on it.Probably sell it.Its rtr too. thanks DON
Pictures would eliminate most of the guesswork. I feel like Gollum; "What does it have in its nasty pocketses?" :lol:
RedScampi  It’s my birthday!
Post by RedScampi »
Well, if you don't have a pic Don, here's one I snagged from this very board...
Gary
DennisM
Post by DennisM »
Please keep in mind -
There´s the Ultima Pro and the Ultima Pro XL.
Gone fishing
THUNDERSTRIKE1
iT LOOKS LIKE THE BODY OFF PIC IN THAT MANUAL.But what makes it the XL model?Don
Mr. ED
Post by Mr. ED »
ok, simplest method to explain: how wide are the rear arms inner hinges spread? If it's clearly less than the inner hinges on the front arms, than you have an XL.
If the rear hinges are a similar distance apart as the front ones, you got a 'standard' pro.
Even simpler: if you got a full length topdeck from front bulkhead to rear bulkhead it's standard.
If it 's just a short bit from the front bulkhead to the top of the servo saver, and another shortbit to mount your ESC on the rear bulkhead... then it's a pro.
(But the full length top might just be on the european version of the standard pro: with the alloy chassis)
Other hints:
-the shorter arms on the standard pro front: with 3 circles seen from the top.
-the pro has wide black frp battery top plates, the standard pro has black nylon parts
-the decals are different between both : see the image above for the pro-xl
All of this might be irrelevant, lots of people don't keep their car standard so you might have a mutation of turbo 2 or whatever
(by the way kyosho never put carbon or graphite shocktowers for the ultima in any kit: they are black frp. As far as I know they never made any as an option-house hop-up either)
THUNDERSTRIKE1
Its definitely the XL
Now i need to tear it down and dust it all off.Trans is super smooth,the prior owner had taken the shocks off an put them on the JRX PRO SO I SWITCHED THEM BACK INTO PLACE.lol Any way soon as im done cleaning will be selling it hopefully by friday.If snyone is into this kind of buggy.Don
losiXXXman
Nice find Don. You sure you want to turn it over? Give her the once over first, then give it a run... you may decide you like the old girl. If not you can still clean it and sell...
Mr. ED
Post by Mr. ED »
Don, just don't put the wrong pinion on your moter: those spurs look like 48 dp but they're not
THUNDERSTRIKE1
Its rtr so its all setup just years of dust on it from a
barn loft an spide webs.DON
Mr. ED
Post by Mr. ED »
good catch: that was really the latest and greatest of that line.
Don't let it go too cheap, just like buying , selling well asks some patience too
Return to “Kyosho Forum”
Users browsing this forum: User avatarSwath, No User AvatarYandex [Bot] and 1 guest
