Rc10gt brushless/trans questions
Dirtcar75
Post by Dirtcar75 »
I am wanting to do a rc10gt brushless conversion and was wondering if the gt trans is the same as a typical stelth trans out of say a t3? If soo i could just use a customworks motor mount and spacers and be done! but otherwise i have seen guys use pan can motor mounts and then have to brace them with tie rods and such because of chassis flex any help would be great thanks dj
romulus22
Has thanked: 900 times
Been thanked: 789 times
Re: Rc10gt brushless/trans questions
Post by romulus22 »
The trans in the GT. is completely different than any other so no mount will bolt right up. There was some guy who made a motor mount for the GT chassis but the pan car mount sounds just as easy. Great idea too.
Dirtcar75
Post by Dirtcar75 »
Ok so what about using like a customworks trans and mount it is pretty much a t3 trans with input shaft out other side
Has thanked: 3699 times
Been thanked: 1980 times
Here's mine. A brace for the motor mount would be something I recommend. I only ran mine a couple of times before shelfing it so it wasn't much of an issue for me. Ran strong though. They convert very nicely.
http://www.rc10talk.com/viewtopic.php?f=36&t=7717&hilit
Dirtcar75
Post by Dirtcar75 »
And its between doing a brushless gt or going out and buying a new 22t
SRTracer121
Post by SRTracer121 »
id pick up a 22, why wreck a gt when you can go hammering on a modern car :wink:
Return to “RC10 Truck Forum”
