RC10GT I picked up today...
cautiousone
Post by cautiousone »
So I got another awesome deal today, this time it's an RC10GT. It came complete with everything needed to run and a few extra parts still NIP. So are these gas trucks hard to maintain? I've never owned anything Nitro before. Also the pull start won't budge on it, any suggestions on that? I'm not sure if this thing will even run or not, it was bought as is and untested. But hey for $12.00, I sure wasn't going to pass it up. :lol:
RC10talk.com is like a bad accident, I just can't stop looking at it...
romulus22
Has thanked: 900 times
Been thanked: 789 times
Re: RC10GT I picked up today...
Post by romulus22 »
The engine may just be gummed up. Pull the head and use some hot water to set the block in. Let it heat soak for a min and slowly add pressure to to pull start. Should free right up if that's the problem. You may find worse right away if you pull the head. Use some new nitro to flush the engine after its free. at least that's what I used to do 8)
cautiousone
Thanks for that tip, I'll pull the head and see what it looks like in there, never really thought about it just being gummed up. I don't have any nitro fuel for it right now, anything else I can use to flush it out with? I can't image to much being wrong with this thing, it honestly looks like it's only been ran a few times max.
romulus22
Post by romulus22 »
If you can just disassemble the whole motor and clean it thoroughly. But make sure to lube all the internals well after its clean before you reassemble it. I use after run oil to lube the parts after I rebuilt mine. Make sure there's no water hiding in bearings and whatnot too.
cautiousone
Well it sounds like I'm in for an adventure, since I've never had any experience with nitro engines before. The thing is I bought this truck to resale, as that's what I do for a living. But the more I look at this thing and as I admire what great condition it's in, I'm leaning towards keeping it. I already have a few vintage RC10's, a team car and a RC10T and honestly I have no room for any more RC cars. So it looks like I'm going to sell off the 10T and keep this nitro instead. I'm sure I'll be bugging ya'll soon for more info if things don't go as planned when I tear down the motor. :mrgreen: Thank you for the suggestions thus far... Damon
cautiousone
Oh yeah, any suggestions on what kind of fuel to buy for this thing? I see many different types offered and I have no clue as how to go about choosing one of them. :roll:
farmer
Post by farmer »
That is the rtr model
The pull start was cr@p AE was exchanging
So many of those
And what sucked even more was that you had
To cut the chassis around the fly wheel
To get it in the starter box
Cell phone post mor later
Farmer
cautiousone
Speaking of that flywheel, should I be able to turn that by hand? I took the head off and it's spotless in there, but I was trying to get a grip on that flywheel and give the motor a spin and it ain't happening.
romulus22
Post by romulus22 »
Looking at the face of the flywheel you should be able to turn it counter clockwise. Go ahead and pull the starter off there too it could just as easily be gummed up in the crank case. Try the hot water for a couple min though too.
cautiousone
romulus22 wrote:Looking at the face of the flywheel you should be able to turn it counter clockwise. Go ahead and pull the starter off there too it could just as easily be gummed up in the crank case. Try the hot water for a couple min though too.
Yeah, I can't make it budge in either direction. I'll pull the engine, it must be as you are saying and something is gummed up in there or worse. Is the pull starter self contained? It's not going to unravel on me is it? I don't want to spend 3 hours trying to figure out how it all came apart. :lol:
romulus22
Post by romulus22 »
Take out the little screws holding the pull starter. Carefully pull it off making sure the center part comes off with the case. Once it's off just tape it together. Then the backplate comes off.
cautiousone
Well, Well, Well, look what I found down in the bottom of the motor, a pile of sludge. Didn't have to soak it in hot water, just cleaned all the goo out of it really well and sprayed it down with WD40 and it works good as new. Did have an issue with that pull starter though, it came unwound on me and I had to rewind it, but it works. :lol: Thanks for your help romulus22, I'll let you know if it starts when I pick up some fuel for it. Thanks again... Damon
farmer
Post by farmer »
those pull starters for the rtr were notorious for the one way going out when i had mine i had to send it in to AE 3 times for exchange shortly after
the release of the rtr it was changed to some other one dont remember it but it was all black
i just cut the chassis to get it to sit in the starter box
it was a pretty good truck for what it was
just dont run it lean
i think i was running 20% back in the day
farmer
cautiousone
farmer wrote:those pull starters for the rtr were notorious for the one way going out when i had mine i had to send it in to AE 3 times for exchange shortly after
farmer
Yeah, I got a good look at that pull starter after it unwound on me and it doesn't look like it's built very well, not made to take any abuse for sure. What about installing a roto start on it? seems like a more practical way to go if the pull start fails.
farmer
Post by farmer »
did you get the body with it?
roto start um i dont know
im sure with some elbow grease and scratching the head it could be possible
farmer
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAhrefs [Bot] and 3 guests
