Wheels for W-5034 and Optima Mid
- Winger
- Has thanked: 20 times
- Been thanked: 5 times
I purchased these narrow tires by mistake, and am now thinking about trying to just find some wheels for the tires. I am wondering if anyone knows of wheels that would be good for these narrow tires to go on my optima mid?
- Bormac
- Been thanked: 11 times
Re: Wheels for W-5034 and Optima Mid
Finding the matching rears will proove to be the bigger challenge I think
I love this tread pattern.
- Jirka
- Has thanked: 33 times
- Been thanked: 24 times
At first there were no Kyosho narrow front wheels and Kyosho drivers used cut rear wheels with those. Cut the inner groove away to make the rear wheels as wild as fronts would be.
Jirka
Jirka
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Like Jirka says, cut the outer ring of the inner part and lower the new ring a bit.
But You can also go for Turbo Optima wheels, here You´ll find narrow fronts.
Rear tires - If You´re willing to pay 50 usd, You should be able to find a set
I had the same problem as You, 4 sets of narrow fronts and no rears. I found some 2,0 tires called dirt paw with the same tread pattern. Here´s what they look like:
Gone fishing
- Bormac
Winger you after 3 peice 2.0" rims but I think Pargu makes them in alloy at both widths.
Scouring eBay will help out a bit.
- Bormac
Looks like Paul has a set of 2.0" rims that include the medium width fronts.
Hope this helps
http://www.rc10talk.com/viewtopic.php?f=6&t=26574&p=269480&hilit=option+house#p269480
Hope this helps
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
The rear wheels are easy to find, rear tires on the other hand...
- phoenix
- Has thanked: 5 times
- Been thanked: 19 times
Would be nice if you'd show us some places where we can find them (new neon yellow rear ones). Thanks !EvolutionRevolution wrote:The rear wheels are easy to find, rear tires on the other hand...
Well, the yellow ones specifically I don't know, but Kyosho wheels that fit rear Kyosho Optima Mid tires are easy, since all Scale Car wheels fit those tires...
- 740 Views
Last post by isobarik
- 4329 Views
Last post by Jester_The_RC_Guy
- 19 Replies
- 9290 Views
Last post by lin6499
- 3297 Views
Last post by Bo Wallen
- 52 Replies
- 13752 Views
Last post by HKS_TRD
- 2011 Views
- 68 Replies
- 23544 Views
Last post by Garage Hack
- 22 Replies
- 7792 Views
Last post by j0pp3
