Easy Off Oven Cleaner / Fairy Power Spray - Remove Anodizing
Re: Easy Off Oven Cleaner / Fairy Power Spray - Remove Anodi
DON'T USE THEM! easy off oven cleaner works really well to remove anodizing. The....blue can? I want to say. The yellow one is citrus based or something and not as effective. I could have that reversed though.
Acetone in a plastic bag will remove stubborn paint without damaging the anodizing.
- LTO_Dave
- Has thanked: 52 times
- Been thanked: 287 times
Yeah, don't use oven cleaner unless you like the look of bare aluminum.
I usually use acetone, paint thinner or brake parts cleaner to remove paint, depending on what surface is underneath. The brake parts cleaner will dull plastics and melt rubber, so use at you own risk.
I know this is an old thread but I have used goof off for removing paint with out damaging the anodizing before.
- 851 Views
Last post by juicedcoupe
- 1009 Views
Last post by nvxwax
- 751 Views
Last post by mikea96
- 1331 Views
Last post by klavy69
- 338 Views
Last post by treehugger
- 1384 Views
Last post by Groomi
- 753 Views
Last post by lpddpd
- 1322 Views
Last post by R6cowboy
