Nose heavy?
Nose heavy?
Hey all...
I've got a resurrected RC10T2 that I've been slowly rebuilding to compete with some of the newer kids at our local indoor track.
The track is very hard pack clay...almost concrete like...
I'm running bar codes on all 4 corners and finally got the thing to track well.
But over the jumps? even with a judicious throttle stab at the lip of the jump...she just likes to nose in to the ground...often digging the RPM extended bumper right in...and then flipping over. I've slid the battery back...with no foams to try and move some weight to the back...But then she lifts her front end with throttle...
She's runnin a 4000mah stick type lipo...35wt oil in the front shocks...30wt rear...green springs...this setup soaks up the bumps quite nicely.
On the straights, she's giving the Losi 22T and RC10T4 guys fits...hee hee hee....
Any ideas gals/guys?
BTW...this was a TOTAL ebay build....Total build cost (including replacement RPM parts...gears..electronics...etc): less than the cost of a T4 team kit...woohoo...
- RC104ever
Re: Nose heavy?
I know it's not the same but my rc10 dies the same. I can't figure it out
- Chris
Lots of cars...so many cars
Re: Nose heavy?
Try a bigger spoiler. I changed the wing angle on my buggy and noticed a huge improvement in how it flew. A bigger spoiler should have a similar effect.
Nick
Nick
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
Re: Nose heavy?
Front:
30 wt shock oil
#2 pistons
stock 30 caster block
2 degrees camber
2 degrees toe out
Green springs
Rear
35 wt shock oil
#2 pistons
3 degree toe IN blocks
2 degrees camber
standard wheelbase
Both front and rear arms are RPM. Ride height set so arms are parallel to ground...just about 200mm or so...Measurements taken with a 2s 4000mah lipo battery...running a 6 cell 5000mah NiMh the rears are just about 2 degrees or less from horizontal.
Track surface is indoor hard packed clay...some glazing...the proverbial blue groove track....tight course however with an uphill double that terminates into an off camber right hand hairpin heading downhill....crazy.
But the big triple...I hit the first one...and even with a perfectly timed throttle pull (rare) the thing nosedives into the last one...frustrating.
30 wt shock oil
#2 pistons
2 degrees camber
2 degrees toe out
Green springs
Rear
35 wt shock oil
#2 pistons
2 degrees camber
standard wheelbase
- Has thanked: 7 times
- Been thanked: 42 times
Re: Nose heavy?
Does it nosedive with the NiMh pack? If not, I'd say add some weight behind the LiPo by stacking some lead squares (4 would probably be a good start) behind the battery. You'll have to adjust your ride height but this should help I would think.
Re: Nose heavy?
Change the rear ride heigt,add somw limiters. if not yet taken care off.
― Confucius
― Confucius
Re: Nose heavy?
limiters added....as for rear ride height...lower? or higher?slow_jun wrote:Change the rear ride heigt,add somw limiters. if not yet taken care off.
I thought the optimum was to get the arms/cvds level?
Re: Nose heavy?
Rear cvd bones level yes, but- if you are sprung too softly or have too light oil the rear chassis will slap on the jump face propelling the rear end forward in a nose down way. Or if your sprung too heavy the same effect can occur.
- 1149 Views
Last post by Basher67
- 1950 Views
Last post by hugger19
- 1887 Views
Last post by FasterLouder
- 1413 Views
Last post by naushad
- 3390 Views
Last post by SMOKE-DOG
- 245 Views
Last post by Dangeruss
- 1947 Views
Last post by soniccj5
- 2432 Views
Last post by gregm
