Cougar 1 transmission
Delorean
Has thanked: 15 times
Been thanked: 14 times
Post by Delorean »
hey guys
just thinking about the cougar 1 and belt drives in general
ive heard the cougar belt drive described as "sluggish", so do people in general upgrade to a geared box out of one of the other models or is the cougar belt drive a good thing?
its got me thinking about belt drives, in 4wds, my feeling is belt is more efficient, in 2wds, there arent many options, A & L lethal weapon can be fitted to a few cars, ive heard theyd get about 30 sec more run time out of 1200 cells back in the day with the belt tranny
i understand its hard to get belt drives to transfer big power motors, i'd more than likely only be running 540 or 17.5 at the max, any thoughts or info would be great
Momo5
Re: Cougar 1 transmission
Post by Momo5 »
I dont have a lot to add to this, but I've got two beltdrive RCs that im working on restoring...a Kyosho Triumph and a Schumacher Cougar 2 Works. I can't wait to drive one of these. Ive never driven a car with a belt drive.
Mad Racer
Post by Mad Racer »
Belts are great.
I have run a 13T Brushless in my Top Cat with no dramas . Had to be carefull of no diff slipp but once adj it was fine.
As with any high output motor a slipper is always better to stop the drive train getting shocked from jump landings and hard take offs. I have just aquired a slipper for my Top Cat which will help it out.
As for belys being Slugish . I have hred that too but i never think so. Infact a Belt drive train is very smooth to drive . Maybe that's why they say slugish. My Top Cat is one of the smoothest 2wd cars i have even driven in vintage.
Delorean
Post by Delorean »
thanks for your thoughts mad racer, this is the weird thing, and it could be more dependant on the particular transmission but some say belts are more efficient, some say they arent, i agree that one of the coolest things would be the smoothness to drive, a feeling which is added to by how quiet they are
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
I think what drove people off belt transmissions (for 2wd, I mean!) is the drag vs. a "classic" 3-gear transmission... Probably it mattered a lot more bitd when we were struggling to make the 5mn mark. Today, with the absence of built-in drag brakes in BL mills and the insane batt capacity it shouldn't be an issue anymore... then there's slippage :mrgreen:
The 3gear transmission structure is so refined by now it would probably take a looooong time to design a belt-driven case that would perfrom as well :)
Paul
Jay Dub
Post by Jay Dub »
From an engineering standpoint, belts are more efficient at high speeds. So the efficiency debate centers around transmission speeds. However, from experience (i did R&D for schumacher for many years) I can tell you that the geared trannies have much better punch in limited power scenarios. -Jeff
Delorean
Post by Delorean »
thanks for the input guys, it actually makes sense when i think about it, a simple 3 gear tranny would be hard to beat, especially for 540 racing
Return to “Schumacher Forum”
