LRP Sphere Competition setup problem.
askbob
Post by askbob »
Has thanked: 306 times
Been thanked: 415 times
Re: LRP Sphere Competition setup problem.
Sounds like you have your transmitter E.P.A. settings somewhere other than 0, causing your throttle "throw" to be very very short from neutral to WFO ( an old trick of mine for stock oval ). Check all of them in your transmitter, make sure you have all expo settings at zero as well. Go back through the setup 1) hold set button for 3 sec until.you get a blinking blue light storing neutral 2) press set again and yellow/red and motor beeps, hold throttle open and 3) press set again holding full brake.
askbob
Post by askbob »
Thanks Reg. I was up way too late without much sleep to try and deal with that last night I suppose. :lol: Figured it out this morning once you spelled it out for me. On my 4pl, it must be that epa of 100 is actually 0. If I set it to 0, I get nothing with the throttle after finishing setup. Works like a champ now.
