RC10GT help
RC10GT help
Im bring my old gt back to life that I got in 89
My slipper slip's even with it very tight ,I can't remember do you glue one side of the pad down
Thank for your help
Thank for your help
Second place is the fisrt loser
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: RC10GT help
Got any pics? Maybe it's a clutch issue?rebuild wrote:Im bring my old gt back to life that I got in 89
Thank for your help
Re: RC10GT help
I'll get some pic up latter to day , I did go through her again , the diff was a hair lose tightin that up , the pin the brake adapter sit's on is good ,I looked very close even fired her up and I can see the slipper clutch slipping I did try glueing down one side of the sliper pad that helped a little but still slips kinda easy , Thanks for your reply and help
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: RC10GT help
How is it slipping? under hard acceleration, barely moves from stop, going uphill, etc. That would be useful info.
Re: RC10GT help
If I stay very light on the gas it will go but soon as I get on it a little bit it slips ,the pad is stock pad that came with it I'll try some 600 grit and ruf it up a bit , today I found that the tub chassie had a little twist in it , one of the front wheels is higher then the other ,so I'll strip it down and try to get it out ,having a hard time find a new one , I may have to go with the blue one
- klavy69
- Moderator
Re: RC10GT help
AE still has them and think they are selling for around $16(?) right now...rebuild wrote: ,having a hard time find a new one ,
doesn't sound like slipper to me you loosened it after pix. Sounds more like diff is loose. Tighten the diff down lightly to locked and try it.
a simple thing to look for also is your drive pin condition in the wheels. I've been at a standstill scratchin my head for a few hours when it was a wheel pin that was actually slipping because of a stripped out wheel
Re: RC10GT help
Thanks for the tips , I'll go throuh again look every thing , do you have a link for the chassie , I when't to the team associated store there out of stock , again thanks for your help ,I'll let you no what I find after I took anouther lookklavy69 wrote:AE still has them and think they are selling for around $16(?) right now...rebuild wrote: ,having a hard time find a new one ,
a simple thing to look for also is your drive pin condition in the wheels. I've been at a standstill scratchin my head for a few hours when it was a wheel pin that was actually slipping because of a stripped out wheel.
- klavy69
- Moderator
Re: RC10GT help
[quote="rebuild], do you have a link for the chassie ,[/quote]
http://teamassociated.com/parts/details/7525/
Andrewsi posted this a few threads lower in this section about his truck and some flywheel/clutch questions...don't know if any are left or what the status of them are but believe they have been f/s at this price for awhile now...
Re: RC10GT help
http://teamassociated.com/parts/details/7525/klavy69 wrote:[quote="rebuild], do you have a link for the chassie ,
Todd[/quote][/quote]
I believe I purchased the last one instock. After I paid for the chassis it was no longer available. I might be worth a shot to call AE and see if they might have any laying around.
Re: RC10GT help
[/quote]AndrewSi wrote:http://teamassociated.com/parts/details/7525/klavy69 wrote:[quote="rebuild], do you have a link for the chassie ,
I believe I purchased the last one instock. After I paid for the chassis it was no longer available. I might be worth a shot to call AE and see if they might have any laying around.[/quote][/quote][/quote]
Thanks I'll call them latter to day , and I'll let you no what they say
Re: RC10GT help
Well I gave them a call ,and they said the the pan chassie 7525 is done there will be no more and have to go to flat chassie , I hope the engine mounts will work on the 7769 flat blue chassie , I Just got one for pull start and for bump start LOL mit be a while be for I pick one up , spent my cash on every thing but the chassie LOL
Re: RC10GT help
you should be able to find GT parts on ebay quite easily. The place is littered with rc10GT auctions, I have to weed through them to look at regular buggy auctions
Is the chassis the same as the Nitro DS?
Re: RC10GT help
Im not sure if its the same as the DS or not , I'll do some more hunting around see what I can find outjwscab wrote:you should be able to find GT parts on ebay quite easily. The place is littered with rc10GT auctions, I have to weed through them to look at regular buggy auctions![]()
- 20 Replies
- 4820 Views
- 2731 Views
Last post by DaveM
- 498 Views
Last post by n33no
- 25 Replies
- 2568 Views
Last post by juicedcoupe
- 631 Views
Last post by Frankentruck
- 32 Replies
- 4756 Views
Last post by romulus22
- 692 Views
Last post by RC10th
- 2519 Views
Last post by justinspeed79
