Can you ID this shock
General info, Q&A.
joel45acp
Post by joel45acp »
It has two o-ring seals inside. Thanks.
In Christ,
Joel C.
Has thanked: 359 times
Been thanked: 470 times
Re: Can you ID this shock
Kyosho gold, or Duratrax- from the anno depletion I'd bet duratrash-
rhino1
Post by rhino1 »
Charlie don't surf wrote:Kyosho gold, or Duratrax- from the anno depletion I'd bet duratrash-
Duratrash is right.
Those are my toys and no I will not share!
joel45acp
Post by joel45acp »
the duratrax had two inner seals too? thanks gents.
In Christ,
Joel C.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
If it's got two o-rings it's a Kyosho Gold. Spring cup looks Kyosho too....Duratrax was flat.
http://www.rc10talk.com/viewtopic.php?f=40&t=15732
joel45acp
Post by joel45acp »
I opened it up and observed two red o-ring at the bottom of the shock body.
In Christ,
Joel C.
Jay Dub
Post by Jay Dub »
Definately Kyosho. Has long lower tie rod ball cup, with AE steel ball, red notched piston, cracked diaphragm, and 30wt brown oil. LMK if you need anything else. -Jeff
Lowgear
Has thanked: 121 times
Been thanked: 796 times
Post by Lowgear »
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Post by littleVETTE »
lmao
joel45acp
Post by joel45acp »
thanks gents. they might be heading to fleabay soon.
In Christ,
Joel C.
Phin
Post by Phin »
How practical would it be to use Kyosho Golds for a runner? Are bladders, and o-rings readily available for rebuilds...and are there modern springs or pistons that can be used?
I picked some up in a couple of eBay lots and was wondering if it would be more cost effective to just flip them then use the funds towards the purchase of new shocks.
Jay Dub
Post by Jay Dub »
Well, the shocks perform better without bladders. Typically you would just cut out the bladder section, and use the outer ring as a seal. The o-rings are a std. 3mm size, so they are easily attainable. The other rebuild parts are avaible too. Plastic parts, clips, etc., (I have a rather large stash as a matter of fact (e-bay as well)) are not that hard to pick up. THe biggest issue is the shafts. IF you bend or breat one of them, they are hardder to find (but not impossible). -Jeff
