Tekin TSC408 esc is it worth fixing?
Jools
Has thanked: 6 times
Post by Jools »
I have a Tekin 'Sport' TSC408 which works only in reverse. How hard is it to troubleshoot something like this? Would it be worth fixing?
(I'm restoring a vintage Scumacher ProCat, ... be nice to have a vintage esc in it).
-Jools
esaresky75
Re: Tekin TSC408 esc is it worth fixing?
Post by esaresky75 »
If you can find someone that can repair it, the cost most likely isn't work it. Here's one on ebay, condition unknown but might be worth the risk or hold out for one that has been tested.
http://www.ebay.com/itm/Tekin-Sport-TSC-408-Speed-Control-/150749252700?pt=Radio_Control_Parts_Accessories&hash=item23195b0c5c#ht_1939wt_933
Burn more coal - UnderGroundMiners.com
highwayracer
Been thanked: 6 times
Post by highwayracer »
If I remember correctly, the 408 was a forward only ESC. So if it doesn't go forward, then your motor leads are backwards. If it's a modified motor, then the endbell must be turned 180 degrees.
Jools
Post by Jools »
Funny that, I thought of switching the motor wires, tried it and it makes no diff !
-Jools
