I recently had a problem with my LiPo, the bullet connector inside the battery broke. I use 4mm bullet connectors on all my buggys and charger. Is it possible that normal use caused this problem?
I thought about leaving the bullet connectors inside the LiPo, then add another 3mm conntor with a short wire on it so It will lessen the unplug, plug on the internal bullets.
Or could it have been a bad battery?
Thanks,
ED
LiPo Bullets
Re: LiPo Bullets
are you talking about the 4mm female internal to the battery? hard case? have you taken it apart and inspected it? can you post a pic? If you are concerned about the wear and tear of plugging and unplugging you could switch to a wired battery.
- 1038 Views
Last post by Diamond Dave
- 509 Views
- 818 Views
Last post by Jayar
- 1684 Views
Last post by bigmd
- 21 Replies
- 1498 Views
Last post by OldSchoolGuy
- 1979 Views
Last post by THEYTOOKMYTHUMB
- 445 Views
- 1146 Views
Last post by rcguy5
