Looking for a good place to order anodized nuts like these
- KyoshoScorpionKid
Hello
I've searched google but I thought I would ask since I know someone uses them, do you have a good place to order nuts like these?
Thanks
Franco
Thanks
Franco
- Been thanked: 325 times
Re: Looking for a good place to order anodized nuts like the
I've purchased lots of items like this from RCMart. I searched the online store for "flanged" and got this, plenty of colors & sizes to choose from. You didn't mention what size of nuts you needed.KyoshoScorpionKid wrote:Hello
Thanks
Franco
http://www.rcmart.com/advanced_search_result.php?keywords=flanged&sort=1a&manufacturers_id=0
- KyoshoScorpionKid
- SRTracer121
also http://www.fastener-express.com/
and tower and a-main have good selection if you know what to look for
http://www.amainhobbies.com/index.php/cPath/1576_699/n/Hardware-Fasteners-Screws-Bolts-Washers
It's good to note that Tower way over-charges for colored nuts. $12.99 for 4 colored lock-nuts?? Really?!
- KyoshoScorpionKid
Doh! No Thanks RCmart has some put I want to find the right ones that can't be the short ones I purchased from fastener-express.
Franco
Franco
Short ones? As far as I can tell, I've seen 2 kinds of anodized nuts; a normal kind and a low-profile kind. Maybe the ones in your picture are the low-profile ones. They come in both flanged and normal style. I wouldn't use the flanged ones unless I needed the nuts to lock onto a plastic surface of some sort. I use the unflanged kind for pretty much everything; shock towers, wheels, suspension link mounting, etc.KyoshoScorpionKid wrote:Doh! No Thanks RCmart has some put I want to find the right ones that can't be the short ones I purchased from fastener-express.
- KyoshoScorpionKid
That's the thing I don't want short profile ones, like the ones in my original post. They are going to be used for Axle nuts so having the short ones on there look terrible.
Franco
Franco
- proffesso
anyone tried home annodizing? or sending a bunch of parts off to get anno'd?
I'm a retro radio control hipster - I only like the stuff no one bought!
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
I think it was Jake(bigjeepzz) that did a home annodizing setup with some really good results. If I remember right he had some mixed results in different items but something like this doin all nuts would be good even coloring.proffesso wrote:anyone tried home annodizing? or sending a bunch of parts off to get anno'd?
Right now someone is getting(might be done now) an order of red annodizing together in the b/s/t area. If I get it the more people the less it is...something about tree counts(?) but its been done on here too.
- Bimdapogs
Tamiya has those colors except purple and pink. Contact Borgfeldt Canada. Glenn will help you out.
- esaresky75
Keep in mind you can anodize aluminum only. Most nuts that are a regular finish (zinc-chromate) are steel.
Burn more coal - UnderGroundMiners.com
- THEYTOOKMYTHUMB
- Has thanked: 3709 times
- Been thanked: 1980 times
I once had my nuts anodized blue just to prove a point to my wife. The process wasn't so bad, but removing it with oven cleaner and steel wool was pretty rough!
- klavy69
- Moderator
Just leave them blue...you'll need to prove your point over and over and overTHEYTOOKMYTHUMB wrote:I once had my nuts anodized blue just to prove a point to my wife. The process wasn't so bad, but removing it with oven cleaner and steel wool was pretty rough!
- THEYTOOKMYTHUMB
Good point!klavy69 wrote:Just leave them blue...you'll need to prove your point over and over and overTHEYTOOKMYTHUMB wrote:I once had my nuts anodized blue just to prove a point to my wife. The process wasn't so bad, but removing it with oven cleaner and steel wool was pretty rough!![]()
Sorry everybody. I will gracefully bow out of this thread before the derailment is irreversible.
- 845 Views
Last post by vwjuice
- 471 Views
Last post by Lowgear
- 737 Views
Last post by aconsola
- 1535 Views
Last post by Mazdaj
- 2931 Views
Last post by badnat
- 770 Views
Last post by shorne
- 1018 Views
Last post by mikea96
- 32 Replies
- 4212 Views
Last post by Lonestar
juicedcoupe and 2 guests
