Airbrushing/masking questions
- slapshot1979
I have a bunch of parma fascolour paints, for the airbrush. What is the best thing to use to reduce for spraying?? laqur thinnner, paint thinner? I dont have access to the parma reducer (cant ship across the border anymore) It is water based but I was told that isnt the best to use.
Also what is a good practice for edging stripes with a thinner line.
I have masked this a few times and there as always a spot which is slightly "out" or get some creep under tape.
Is it just practice or is there another way of doing it?
Thanks guys got a bunch of bodys to do shortly
- Has thanked: 36 times
- Been thanked: 1319 times
Re: Airbrushing/masking questions
don't use lacquer thinner, it's waterbased.
i haven't used faskolor yet, but i remember doug posting something about reducing with clear window cleaner. someone else can chime in on that.
- Been thanked: 325 times
I've read that using regular Windex is fine, and to thin the Faskolor to the consistency of milk...
- slapshot1979
seriously?? I never would have dream't this.
I read it over on RCTech.net, in a topic with about a bazillion pages...which is about normal for that site.slapshot1979 wrote:seriously?? I never would have dream't this.
- slapshot1979
not a member there but Ill try and search for it. thanks
- slapshot1979
slapshot1979 wrote:not a member there but Ill try and search for it. thanks
Wow there is a whole other rc world out there other than rc10/clod talk.....amazing....
The problem with that site is finding those 3 useful posts in a topic having 400 pages.
- phoenix
- Has thanked: 5 times
- Been thanked: 19 times
faskolor usually needs no thinning and is ready to use. I use Fasmask for masking, be sure to apply some coats though to prevent it being to thin in the end and a pain to peel it off.
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
I tried Faskolor and I thinned it my usual way 1/2 and 1/2. It was waaaaaay to thin. It just ran off and pooled in the corners. If I were to do it again I would shoot it straight from the bottle. If it is too thick add 1/10 water/windex/whatever and try again. Repeat until you get the desired consistency.
And TEST, TEST, TEST before shooting your body.
Yes, it's a good idea to test on some cut-up sections of plastic 2L soda bottles. I also don't think FasKolor should be thinned; it's not like Pactra, it's made to spray on as-is.
- 8rad
Based on my personal experience i would think that this is correct. What does the bottle say?I also don't think FasKolor should be thinned; it's not like Pactra, it's made to spray on as-is.
It's not necessary to thin the paint...in fact, you're supposed to be able to attach many airbrushes directly to the FasKolor bottles.8rad wrote:Based on my personal experience i would think that this is correct. What does the bottle say?I also don't think FasKolor should be thinned; it's not like Pactra, it's made to spray on as-is.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
until I got a good airbrush with multiple spray tips there were a few colors that had to be thinned. Colors escape me now but I know there were 2 for sure I had to thin but since I got the new brush I have not had to thin this paint. Switched out to a heavier tip and walla...no thinning. You shouldn't have to thin this paint but I have tried the window cleaner with no problems. I don't know what it did to the strength or etching ability of the paint but I only added enuf to get it to spray so it shouldn't have lessened its integrity by much...if any.
- slapshot1979
It does say spray from bottle but it never sprays right for me I tried different tips and pressure and although it will work for large areas, but for smaller stuff it wont. I will have to try I guess.
- 1080 Views
Last post by HawkeyeLTS
- 2510 Views
Last post by 2500M_Sub
- 626 Views
Last post by GreenBar0n
- 27 Replies
- 3078 Views
Last post by juicedcoupe
- 3436 Views
Last post by Benders
- 1686 Views
Last post by WillyThickfoot
- 1139 Views
Last post by LoboNYC
- 1824 Views
Last post by Chewbacca
Users browsing this forum: Amazon [Bot] and 3 guests
