Losi motor info.
PTModIT
Losi motor info.
Post by PTModIT »
Hi, I have a Losi Revolution Racing Motor. It has the black can with yellow and brownish red lettering.Bearings on both ends.There are 2 white lines or markings on the windings from the pinion side.Either the marker was too big and it should be one. But 2 lines for sure.Any info on this motor? Thanks.
Has thanked: 359 times
Been thanked: 470 times
Re: Losi motor info.
It's a revolution modified, you can tear it down and find out the wind- they came with early non heatsink endbells and gold heatsink endbells.
PTModIT
Post by PTModIT »
Thanks for the reply.The endbell is black with no heatsink.I did have it apart.All I see is those white markings.What should I look for about how many turns . Thanks.
Jirka
Has thanked: 33 times
Been thanked: 24 times
Post by Jirka »
It might help I You know is the motor double, triple or quintuple wind? Two marks on can might be a Revolution II 18x3 wind.
Jirka
Return to “Losi Forum”
