Mechanical Brushless Timing
- soniccj5
Purchased a Novak Ballistic 17.5/GTB2 combo so I could race in the 17.5 class. My motor came from the factory with 30degrees of timing already set, and from what I read they do not recommend going down to 0.
Does anyone have experience with this motor, and how to adjust the timing to compete in a spec class without ruining it?
Thanks,
ED
Thanks,
ED
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 470 times
Re: Mechanical Brushless Timing
The colored timing ring dictates how much you can advance it ( maybe 12 deg?) But if your running spec blinky mode, I don't believe your allowed to adjust. Also, regarding the timing 30 deg would make your 17.5 like a 30.5
- soniccj5
I already had a Havoc 10.5 combo, so that is why I bought the GTB2/17.5(switch motors between buggys) I want to run in spec/blinky and VONATS with the 17.5 Ballistic, but now I am starting to worry this is not possible.
Vonats was a gentlemans agreement to run non boosted/ timed no actual blinky mode required if I am correct.
- soniccj5
Yeah, there is no tech inspection at the VONATs, and I have no problem setting it to 0, but Novak does not recommend that...Charlie don't surf wrote:Vonats was a gentlemans agreement to run non boosted/ timed no actual blinky mode required if I am correct.
I was still thinking that it was a non boost, non esc timing more than mechanical. Might be wrong-
there's plenty off boost and timing run at the vonats.
IIRC you can adjust motor timing on the motor in blinky classes, just not on the esc.
- soniccj5
So that is why my Trinity Co27 can never make the A-main, and I was thinking it was my horrible driving
- 798 Views
Last post by LTO_Dave
- 812 Views
Last post by naushad
- 2352 Views
Last post by Biggs
- 750 Views
Last post by Heffay
- 938 Views
Last post by Kyoshojoe
- 811 Views
Last post by Dadio
- 1650 Views
Last post by Greenie
- 1383 Views
Last post by Winger
