Picked up a pro xrt sst vintage roller from Ebay for 39.99
KyoshoScorpionKid
Post by KyoshoScorpionKid »
I have always loved this truck, it's basically a Pro-X but a truck wih awesome tranny and so fun to drive.
Franco
lebowski770
Re: Picked up a pro xrt sst vintage roller from Ebay for 39.
Post by lebowski770 »
I would highly recommend opening that transmission box up and checking to make sure the main differential balls are well lubed/not damaged and also tighten it up nicely. My nephews pro-xrt transmission appeared to be in good shape for the first 5-runs and eventually a the differential gear melted from over heating the diff balls were melted in the plastic and had a somewhat difficult time finding a replacement differential.
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
lebowski770 wrote:I would highly recommend opening that transmission box up and checking to make sure the main differential balls are well lubed/not damaged and also tighten it up nicely. My nephews pro-xrt transmission appeared to be in good shape for the first 5-runs and eventually a the differential gear melted from over heating the diff balls were melted in the plastic and had a somewhat difficult time finding a replacement differential.
I totally agree! Back in the days when we got the pre-production Pro-X buggie, we had grate problems with the diff melting down! In my opinion, that was a shitty tyranny and one of the biggest resound I left the Kyosho international team. When the car went in to production most of the tyranny problems was solved, but not all of them. Apart from that, it’s a nice car to drive. I still have my pre-production car.
Nice score still. :D
Cheers
Lars
My Feedback
lebowski770
Here is the thank you video of me and nephew made to member AdamLancia for sending us the differential gear. We turned the esc to the lowest setting as we wanted to "break in" the new differential.
http://www.youtube.com/watch?v=IgmKWnNUxbg
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
Why Kyosho went "backwards" to an LRM-type tranny with the Pro-X cars remains a mistery to most of us...
gotta take pics of my new built Pro-XRT to post here ;) Not sure about the denomination but yours seems to be the "sport" version without the equalizer shocks. if there are so many diff issues with the car, I would recommend you swap any plastic/metal bushings for proper bearings in the trannt, in case kyosho would have used the cheaper solution BITD.
no matter what, for $40, nice score for sure!
Paul
Hcp22
Post by Hcp22 »
Lonestar wrote:Why Kyosho went "backwards" to an LRM-type tranny with the Pro-X cars remains a mistery to most of us...
Paul
I think they signed up an old Losi engineer and develop the tyranny in US together with some team drivers. And I thing they also was former Losi... This is what I’m have been told 20years ago if I remember it correctly
Cheers
Lars
My Feedback
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
The best solution to any SST equipped vehicle (other than shelfers) is to replace the entire transmission with an A&L Lethal Weapon. It's the nicest, smoothest ball diff that you can get for a Kyosho. It's right up there with the Stealth diff. I could never get the SST diff smooth. If it was smooth, it was too loose and slipped. Tight enough not to slip and it was gritty.
KyoshoScorpionKid
When I get it I will pull the tranny apart and see what its like. Thanks for the info.
Franco
Lonestar
Post by Lonestar »
Paul
thanks for info - looks like the only possible reason, really... They should've hired someone from AE instead :D
Paul
Hcp22
Post by Hcp22 »
Lonestar wrote:
Paul
Paul
You are welcome, and I totally agree with you, they lost many drivers for that resound. I left for Losi XX, but I drove the Lazer ZX-RR for another year until Losi realest there 4WD.
Cheers
Lars
My Feedback
KyoshoScorpionKid
I found this web site, is this what I need for that truck?
http://vintageteamaandl.com/lethalweapon.htm
Franco
8rad
Has thanked: 9 times
Been thanked: 38 times
Post by 8rad »
Get the power clutch.
adam lancia
8rad wrote:Get the power clutch.
Yup, hat he said :)
mamadoesntletme
Been thanked: 16 times
Post by mamadoesntletme »
That car is very cool,I always wanted one.And a Pro X too! :D
KyoshoScorpionKid
There is another one on ebay right now nicer than the one I puchased.
Franco
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarTbot [Bot] and 2 guests
