Can I control servo thru the ESC signal wires??
slapshot1979
Post by slapshot1979 »
Not sure if this is in the correct area? I want to be able to control a small servo thru the signal my ESC gets from the reciever. So basically a Y-harness from motor channel on reciever. What I hope to have as end result is a servo in neutral when ESC is in neutral. servo swings 1 direction when in forward and opposite when in reverse.
Is this possible??
Re: Can I control servo thru the ESC signal wires??
i've never tried it, but it should work. you won't be able to switch it's direction (without a y-harness that does it for you), or center it. but, with a creative use of servo horn position and linkage, you can probably get whatever you want the servo for to work fine.
slapshot1979
Yeah thats what I had in mind. linkages will have room for adjustment. Ive been thinking about this for awile and just wondering if there was something I was missing
Its done all the time in aircraft so it should work fine. I wanna see what this could be it sounds very interesting...
Has thanked: 3699 times
Been thanked: 1980 times
Reminds me of the toy r/c cars that go straight forward, but turn in reverse. It would take you 30 minutes to get the thing turned around. :lol: This does sound interesting though. :D
huminski
Post by huminski »
It will definitely work, just use a Y connection like you said. I have done this quite a few times, using a micro servo to trip a micro switch to activate a brake light circuit whenever I hit reverse on the transmitter. Works perfect.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
someone trying to get mechanical brakes? ;)
paul
soniccj5
Post by soniccj5 »
I would like to configure a horn on my third channel. So when I flip I could use it to call for help.
ED
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
soniccj5 wrote:I would like to configure a horn on my third channel. So when I flip I could use it to call for help.
ED
or use the extra servo to get your car flipped over without any marshall help :idea: :lol:
Come and visit the stable
esaresky75
Post by esaresky75 »
ED
Life Alert for RC.... "Help...I'm upside-down and there's no turn marshall".
Burn more coal - UnderGroundMiners.com
