Recommendations for dyeing plastics
- njdriver04
Want to find a good dye to make old plastics that were dye back to white, I have found letting them sit in a 1/4 bleach water for a few days helps but it only goes so far.
- njdriver04
Re: Recommendations for dyeing plastics
hope this is not redundant question, where can i get a good white dye.?
- Been thanked: 325 times
I don't think such a thing exists, I'm afraid. RIT Dye comes in plenty of colors, from which hundreds more can be made, but none are white. RIT Dye does come in a "color remover", though...but I've never tested it, and it probably only works to remove color originally dyed with RIT Dye in the first place.njdriver04 wrote:hope this is not redundant question, where can i get a good white dye.?
http://www.ritdye.com/store/
Unfortunately, un-dyeing colored parts other than mentioned above is probably not very feasible. Priming & painting them white might be your only recourse.
- njdriver04
I am going to try white acrylic ink from AC Moore, expensive but will try, acrylic is a plastic base i think or something along those lines
- njdriver04
the acrylic ink was a failure, going to use rit color remover then the rit white wash
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
If you want to save a couple bucks forget about it. Won't work. Your best bet is to start scouring ebay for the parts you want and just replace them. Once you get them you can have black spares or you can get some Rit black dye and get them a nice dark black again, resell them and try to get some of your money back. Good luck
What Todd said. Generally speaking, you can dye something a darker color than what it was previously, but not vice-versa.
BTW, bleach will make Nylon parts brittle and chalky. Best not to use it. Peroxide only
. -Jeff
RIT does work I was surfing Youtube and there were a couple of how to's there. Now this is to dye it a color not to remove color.
His question was how to UN-dye plastics (or dye them white). Of course RIT dye works to dye nylon & plastics, it's very well-documented on this site.Zmd73 wrote:RIT does work I was surfing Youtube and there were a couple of how to's there. Now this is to dye it a color not to remove color.
- GodSpeed
Does Rit dye make the plastic/nylon parts more brittle?
I've read that (near) boiling them can rejuvenate old parts, but I'm wondering what effect the dye itself has, if any.
Also, how long does the benefit of boiling last? Do the parts return to their old state after a short time or does th boiling have an excellent long term effect?
RIT dye shouldn't make parts more brittle; as you said, boiling nylon parts in water actually does rejuvenate them and strengthen them. People have been dyeing nylon parts for years and I've never heard anyone complain about them becoming brittle after dyeing. The dye impregnatesGodSpeed wrote:Does Rit dye make the plastic/nylon parts more brittle?
- GodSpeed
Great, thanks.
Too bad there's not a white dye to make older parts look new again.
I'll see what just (near) boiling them does for cleaning up and rejuvenating them.
Has it been discussed on here what Rit dye combinations and available hobby paint colours can closely match each other and, specifically, the Original RC10 orange?
I'm thinking of doing the wheels.
- 9465 Views
Last post by THEYTOOKMYTHUMB
- 21 Replies
- 2599 Views
Last post by DennisM
- 33 Replies
- 3706 Views
Last post by 8rad
- 1153 Views
- 1407 Views
Last post by GreenBar0n
- 1139 Views
Last post by RC10th
- 127 Replies
- 6327 Views
- 763 Views
Last post by shodog
