First restoration Cougar
- Has thanked: 25 times
- Been thanked: 29 times
Hi Guys, new to the forum, been reading up lots on here on your nice Cats/Cougars etc
I used to race a Cougar Club10 back when they first came out and wanted one of these but couldnt find one so bought a Cougar 1 I think:
Here is a link below:
http://www.ebay.co.uk/itm/170740027170?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I'll see what bits it needs but will need a gear cover if any one has one??
Also is there a manual available to download?? I have checked Schumachers website but cant see one for the Cougar.
If in doubt go flat out!
Re: First restoration Cougar
That was quick, thanks alot! Now to try and find a gear cover now I know the part number
U215A......... let the search begin!
I'll post up some pics when it arrives off ebay
I looked at that on Ebay
But i have far too many cars to finish at the moment to go buying more..
Nice buggy for a restoration though. Looks like it has one of the red GPM shock towers on the front. Also looks like you going need a front bulkhead/front suspension plate.
Paul.
Paul.
Hello Paul
Long time no speak, check your inbox on all forums...
May have some front wishbones Mr Heading....
Cheers Mick
Cheers Mick
You can still get the bulkhead direct from Schumacher, part no : U322. It might not look exactly like the original one but should fit fine. They made running changes to the part so it has extra bracing and i think they come with 3 holes for an external bumper now too.
Paul
I've PM'd you back
Paul
I don't regularly sign in to Oople Mickmoozo wrote:Hello Paul
Long time no speak, check your inbox on all forums...,
Cheers Mick
Hi guys, still waiting for the ebay Cougar in above link to turn up but bought this for spares.
Is it a Cougar 1? Whats with the lowered front end?? was this for use when you ran a touring shell??
I also have 1 x roller drive shaft, are these a good upgrade back in the day?
Here are some pics of what I have so far.........
That looks mostly Cougar 1/Club 10 and it does look like those mounts are for a touring shell.
The spare gearbox you have there is interesting though, looks like you have an alloy gearbox housing on it. It's hard to tell with the pictures what diff is in it too.
Paul.
Paul.
cheers for the info Paul, yes its an ally transmission case on that spare gearbox, not sure about the diff?
When I start re-building it i'll get some better pics.
Not sur if they used the laydown shock front end for off road?? I may build up 2 x front ends and try them out!
Hi Guys, Merry Xmas and New Year!
Just started the strip down of the E bay Cougar, looks all there really.
I have bought a new bulkhead and will start cleaning/re-building soon. So far I have stripped it and given it a basic clean: Here are some pics:
Not sure what make the front alloy tower is, any ideas??
Also not sure what finish to go for on the chassis, do I sand and polish it, or powder coat?
One other question, the front wishbones are very worn (T333 part no), are there any more modern Schumacher cars that use these style of wishbone I can buy new??
Mark,
the part # is u774 comes with wishbones, hub and steering blocks is this what your looking for or are you after something different.
Oh and i think the shock mount is from pk racing?????
Mick
Mick
- 20 Replies
- 2957 Views
Last post by CAT3K
- 1753 Views
Last post by moozo
- 1178 Views
Last post by Asso_man!
- 3369 Views
Last post by Bormac
- 1649 Views
Last post by Robin
- 37 Replies
- 4583 Views
Last post by RichieRich
- 1586 Views
Last post by Retro rc
- 1018 Views
Last post by Bormac
