Tekin small red and black wire?
- slotcarrod
- Been thanked: 45 times
I need your help! I have an older Tekin, not sure what it is but it says Pro Tempfet ESC on the label! Anyway I am putting it in a 4 cell RC12L and can't remember if I solder the tiny red and black wires together for 4 cell use, or not?
Rod Littau
- caesar
- Has thanked: 183 times
- Been thanked: 174 times
Re: Tekin small red and black wire?
Here is a link to all the old tekin esc http://www.teamtekin.com/archive.html
The pro tempfet manual is there.
Hope it helps
Cheers
Rob
Hope it helps
Cheers
Rob
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Yes, you have to join these two tiny wires for 4-cell use!
Come and visit the stable
- caesar
Just looked it up in the manual.
"4 Cell Option; run a jumper wire from the black switch wire to the red receiver wire in order to bypass the regulator. Do not connect to more than 4 cells after doing this. This modification is required for proper 4 cell operation"
- slotcarrod
That's perfect information! Thanks guys!
I didn't know Tekin had an archive, that may come in handy later as well!
Rod Littau
- 1967 Views
Last post by old_rc_lover
- 51 Replies
- 7570 Views
Last post by Prince Steve
- 1066 Views
Last post by flipwils11
- 924 Views
Last post by YZ-10
- 2696 Views
Last post by slapshot1979
- 1060 Views
Last post by Norman
- 1191 Views
Last post by Erich Reichert
- 1515 Views
Last post by KidAgain
