91 Masami Stealth replica (Photo Comparison Uploaded)
- Has thanked: 788 times
- Been thanked: 2252 times
Re: 91 Masami Stealth replica COMPLETED!!!!!!
team associated 4449
http://www.teamassociated.com/parts/details/4449/
if you look up the number tho, they have changed colors, you might get these under the same number
Factory Works website
ask and ye will receive!
I LOVE this place!
thank you gomachv!!!
I LOVE this place!
Hi, my name is Ed, and im a addict.
- slotcarrod
- Been thanked: 41 times
edwin pibal wrote:im not!gomachv wrote:5 degrees ain't even worth talking about, it's a replica. hell until they actually measured it none of them even knew, including the guys that built and raced it. I'm not sure why we are hung up on this detail.
im just soooooo looking forward to having my hands on a 91 stealth car, even if it is a replica!
Ed
I know how you feel. I'm also excited to finally have the car I have been waiting on for 23 years (same age of my daughter ). I remember calling AE long distance every month "When would it come out?" . I was always kept in hope by them, and then the Worlds came out three years later. So happy to see this car reaching our hands after 23 years!
Rod Littau
- slotcarrod
The Losi 4-40 mini nuts have a slightly closer shade of gold and they are cheaper LOSA6306 $4.99 retail for 10.
http://www.amain.com/Losi-4-40-Aluminum-Mini-Nuts-10/p7816
I'm sure there must be some way to make the gold fade, maybe a quick shot of oven cleaner or purple power and a quick rinse?
Rod Littau
- askbob
Rod beat me to it. The Losi nuts come in a few different shades of gold depending on how long they've been sitting around. My experience anyway.
Losi parts on a Stealth car? Sacrilege!
- slotcarrod
I know right!gomachv wrote:Losi parts on a Stealth car? Sacrilege!
Rod Littau
- Been thanked: 4 times
It's called detail. I personally hate 30° and would have done the 91 car in 25° too (although 20° would be even better for performance!) but since it was an unknown with the 91 car, it's nice to at least be sure what it is with the 89 car. Saying that, I won't personally build each car with exact detail to Masami's cars anyways.gomachv wrote:5 degrees ain't even worth talking about, it's a replica. hell until they actually measured it none of them even knew, including the guys that built and raced it. I'm not sure why we are hung up on this detail.
- Seabass
- Business Member
- Been thanked: 12 times
[quote="fredswain"] although 20° would be even better for performance! [quote]
I don't claim to be the end all be all to RC racing but this intrigues me. I think it is quite interesting that you say this when most (and I mean most) setup sheets from all the pros on newer cars are not using 20 degree of kick up. The TLR 22.20 can be adjusted from 20 - 30 degree, yet every setup sheet I have seen shows the guys running 25 degree.
I run my B5 and B5M and I have yet to see a setup sheet where the guys ran anything but 25 degree.
Please tell us more about the 20 degree. I am not poking, I just don't understand.
Jake
Jake
A lower kick maintains more on power steering coming out of corners. The downside to less kick is that it doesn't absorb bumps as well on very rough tracks. Most tracks aren't real rough anymore though. A 4wd car doesn't corner better only because the front wheels pull the car around better although that's some of it. On the contrary FWD cars tend to understeer. Some of that cornering ability comes from low front kick.
A cheapo and easy method to dye the Shapeway parts is in the URL below.
http://www.rc10talk.com/viewtopic.php?f=99&t=36595
- Has thanked: 750 times
- Been thanked: 26 times
O.K Guys,
Here's a theory for you, the car started out 30' but Masami ended up using a 25' kickup chassis and
by using the same front bulkhead, this is why his top plate has cracked/broken in the pics.
I would like to see Masami's car measured
Cheers, Dave.
Cheers, Dave.
I know some say this is a waste of time to talk about but I actually find the debate on it kind of fun. Masami tried all kinds of things. Take a look through his website sometime. It's pretty neat to see all the variations on his cars. It wouldn't surprise me one bit to learn that he tried shimming the bulkhead to change the front kick. That could certainly explain how the car was built with 30°, but appears to be 25° in some shots and 20° in another. If Cliff and Curtis say that it was originally 30°, I believe them. Shimming would explain the angle of the broken top deck. Having Niki and Jake build this car with 25° and then offering optional kick front bulkheads would actually be perfectly in the spirit of it and some fun options to play with. At the 91 Finals, Losi had the JRX-XX prototype which was a JRX rear end with what ended up essentially being the XX front end. Losi was playing with altering the front kick on that car so it's conceivable that Masami picked up on this and messed with his as well.
- slotcarrod
fredswain wrote:A lower kick maintains more on power steering coming out of corners. The downside to less kick is that it doesn't absorb bumps as well on very rough tracks. Most tracks aren't real rough anymore though. A 4wd car doesn't corner better only because the front wheels pull the car around better although that's some of it. On the contrary FWD cars tend to understeer. Some of that cornering ability comes from low front kick.
If you watch the video of the Stealth cars in the surfs up section, they are out of control compared to... dare I say?.... The Losi. 30 degrees would have helped with this one section, judging from the video I would say they are running 25 degree.
Not a big deal what it comes with now as it is little difference in how it looks, but I will get the option parts for my runner/racer when they come out!
Rod Littau
Losi claims that this advantage was due to the hydradrive allowing the rear wheels to slip a bit more than the AE cars over the whoops. It was the rear end, not the front end, that was getting out of shape. I personally believe it had to do with shock pack.
- 119 Replies
- 21176 Views
Last post by Ucsdmutt
- 22 Replies
- 2396 Views
Last post by AndrewCooke
- 1879 Views
Last post by Phin
- 120 Replies
- 12562 Views
Last post by 59burst
- 963 Views
Last post by obsidian
- 22 Replies
- 3843 Views
Last post by dldiaz
- 25 Replies
- 6230 Views
Last post by mikea96
- 1364 Views
Last post by Mark Flores
Users browsing this forum: Bing [Bot] and 0 guests
