Another RC10T fan
Tombsy
Another RC10T fan
Post by Tombsy »
Hey All
I just found the board when I dug out my old RC10t's that I've had since my old racing days. I was pretty serious back in the early 90's in Canada, I went to the Nationals and regional Roar races mostly in stock classes. It was getting pretty pricey trying to keep up with factory drivers so I pretty much packed it in and played around with a Revo and a T-Maxx but a few years ago i got back into racing with nitro and FE boats. It's a whole other ballgame but I'm hooked.
Anyway that's my story I have 2 Team trucks and all my racing gear I've managed to hang-on to over the years so I'm putting a brushless system in one to take advantage of the all the lipo packs i have from boat racing.
The truck I'm using was full race in '94 and I'd like to keep the hydra-drive on it if I can find some fluid - talk about unobtainium. If not I'll probably put the B4 slipper on it.
Thanks for all the great info!
Here's a before pic
slotcarrod
Been thanked: 45 times
Re: Another RC10T fan
Post by slotcarrod »
Very cool, welcome to the forum! For your Hydradrive, I think you can use 1000 to 10000 silicone diff oil! :wink:
Where you at in Canada?
Tombsy
Post by Tombsy »
Hey thanks Rod, I fixed up my location maybe it was you I asked about fluid at PM :D
I ended up finding a new hydra-drive and a rebuild kit both with fluid at ML. There was a dusty old HPI Dodge 10T body that I grabbed too.
I'm just waiting on my electrics that seem to be stuck at the border. I haven't run the truck since the old MORRAC days but I might have to check out the indoor track.
Tombsy
Post by Tombsy »
Well I got the tranny, hydra-drive and the shocks rebuilt, installed the Xerun system and got it all programed on the PC. That part is pretty cool it sure beats counting beeps. Of course the day I finished it snowed but I have to get after painting the body.
Any one remember the Litespeed motor mount?
slotcarrod
No it wasn't me you talked to at PM. I'm in the train and general hobby section now!
Litespeed heat sink and total tranny looks great!
vintage-tman
Post by vintage-tman »
were did u get your hydradrive for the t i need it for mine my slipper slips like mad. and can you help me on my form (vintage 1992 rc10t restoration and need help)
slotcarrod
vintage-tman, The Hydradrive may not get rid of your problems. First check your diff that it is not slipping, by wedging two flat screwdrivers in the outdrives and then try to turn the diff gear with a good bit of force! If it turns, you need to adjust it just to the point where it does not turn! After that check and make sure the slipper pads, bushings etc are all assembled properly. Tighten your slipper all the way. Your car should roost or wheely with no slipping. Then back off your slipper so you can hear it slipping/whining for about one foot from a dead stop! This will get you in the ball park for adjustments! Hope this helps!
vintage-tman
thanks for the help man i founf a new mod that helps i used 4 washers and cranked down on 5/40 lock nut and now cant keep the front end of my truck on the ground. you should check out my new form (vintage rc10t restoration and need help)
Return to “RC10 Truck Forum”
