Topcat chassis clean-up
mogul
Post by mogul »
Does anyone have advice in how to cleanup the metal chassis of a Topcat?
I recently accquired a chassis as part of a restoration project, but the underside is in terrible condition. There is a huge amount of super glue for some reason, and it looks as though the previous owner has had a go at removing it using sand paper. I think I can remove the glue easily enough, but the scratches and general scuffs are a problem.
Moggie XL
Has thanked: 9 times
Been thanked: 14 times
Re: Topcat chassis clean-up
Post by Moggie XL »
I had the same problem mogul and all you can really do is get some wet and dry
paper and spend hours sanding it down.Mine isn't perfect but it's much nicer then when I first got the car.
uzzi
Post by uzzi »
Dip the chassis in a container of acetone (with lid) the super glue will come off....this would then expose the bare chassis to tackle the scratches.
mikedealer
Post by mikedealer »
without looking at it, u can do a few things mentioned here already. if its really bad and u want to really get it perfect, u can use a FINE wirebrush with a drill, and brush the chassis down to a even baremetal finish. Then sand the heck out of it flat, then polish with wheel or rag/compound depending on finish you want. ive done this to have a RC10 chassis re-finished and anodized, and for the price of chasssis's it almost wasnt worth the effort i put in, but came out really nice.
the wirebrush will leave some grooves and pits that sanding will be the only way to smooth out. a FINE sanding wheel is key, dont get something from a hardware store made for cleaning welds or something lol. Fine brass wire ones should do it.
john73
Post by john73 »
Sand blasting is the option i took, it got rid of the minor scratches and reduced the deeper ones
http://www.rc10talk.com/viewtopic.php?f=28&t=22405
I still have not decided on the finish
4x Procat
2x Cougar
1x Cat XLS
tamiya_d1_junky
Post by tamiya_d1_junky »
you can just sand it with an orbi, keep going down grades of paper to get the desired result, easy as to polish up with a buff on a bench grinder 8)
I LOVE VINTAGE!!!
8rad
Been thanked: 38 times
Post by 8rad »
Sand blasting is the best. The Topcat chassis has a lot of nooks and crannies that are hard to get into with a sander/buffer.
I would be willing to do it for you if you send it to me.
mogul
Post by mogul »
Thanks everyone for your comments.
Brad- thanks for the offer to sand blast it. I'll have a go at cleaning it here first and see how it comes out. It's in pretty bad shape, so may never really recover. I'll get back to you later if it is ok?
Return to “Schumacher Forum”
