JRXT-RPM
JRXT-RPM
I have asked a few of you on here this question. I would like to get a vote from the rest of you.I have had 3 sets of RPM A-arms for my JRXT and they rub a little bit on the chassis where they connect to the front bulkhead. In the past, I have just sanded a little of the A-arm but I won a JRXT off of ebay and someone had notched out the chassis with a dremel tool which to my serprise, It looks really good. So, which do you vote for, sand dowm the arm or notch out the chassis? Thanks
Re: JRXT-RPM
a lttle of both wont hurt
what if u raise the bulkhead with shims, or make a spacer plate out of Kydex?
i just shaved a "little of both" bulkhead and chassis to fit an ano blue aluminum (Trinity?) NXT front bulkhead, to fit a JRXT chassis. had to spray it black to match
Re: JRXT-RPM
Great idea on the shims/spacer!!!! I'll give that a try....Thanks I hate sanding or notching anything. Im sure it dont, but I feel like it makes it week.
- highwayracer
- Been thanked: 7 times
Re: JRXT-RPM
I have sanded the edge of the chassis to get the rams to fit. Not that much material needs to be removed...and it can't be seen since the majority of the bulkhead covers it.
The original jrx2 bumper mounted between the chassis and the front bulkhead....so the idea of shimming it has been around. The only problem by raising the front bulkhead is that it caused the tie rods (on the steering rack) to pop off after a hard frontal hit. That's why losi redesigned the bumper.
- Been thanked: 12 times
Re: JRXT-RPM
That's what I have done with rpm/andys/robinson arms. all need a little chassis trimming to have free movement. you can't really see it once everything is bolted up.highwayracer wrote:I have sanded the edge of the chassis to get the rams to fit. Not that much material needs to be removed...and it can't be seen since the majority of the bulkhead covers it.
- 25 Replies
- 4918 Views
Last post by Lavigna
- 1504 Views
Last post by JK Racing
- 1496 Views
Last post by KV78
- 1878 Views
Last post by howsyouraspen
- 24 Replies
- 2543 Views
Last post by richard.bratton
- 1048 Views
Last post by GJW
- 1436 Views
Last post by RC4X4
- 983 Views
Last post by bully
Users browsing this forum: DotNetDotCom.org [Bot] and 9 guests
