Lipo cutoff
- Regular Member
Lipo cutoff
Just had my first run yesterday with my new B4.1 brushless. It is running the standard Reedy3300kv motor and ESC. How do I know when the low lipo cutoff is active? I was too cautious to run it down too low. Was going forever it seemed.
What does it do to let me know it's out ?
- filzemail
Re: Lipo cutoff
Since you bought a brushless buggy, the factory tuning should have included lipo cutoff. Go through the manual for the esc and follow the instructions, step 1, battery management system. You eventually have to learn how to adjust all the parameters of your buggy anyway, so you might as well play with it until you can make it do as you wish with out the manual. It will definitely come in handy when you get to wow a novice with your vast knowlege of the factory electronics..
- Regular Member
Re: Lipo cutoff
Yes I can use the setting procedure for the ESC. I figured that all out in 5 mins. I just don't know what the indication is when driving to inform me it's finished. Does the ESC interrupt?
- soniccj5
Re: Lipo cutoff
My SC10 should have the same ESC that your B4.1 came with. When mine is low it shuts down for a few seconds. Almost like the reverse to forward stop. I usually run it until it starts to slow down then I pull it off the track.
- filzemail
Re: Lipo cutoff
I have two different brushless esc's and both shut down the drive for a couple of seconds but the steering still operates normally. You will also notice a definite loss of power as the cutoff point gets near. If ever you are unsure, just take the car off and check the voltage of the battery with a meter so you know what the voltage is around cutoff time..
- 1053 Views
Last post by Diamond Dave
- 524 Views
- 833 Views
Last post by Jayar
- 1706 Views
Last post by bigmd
- 21 Replies
- 1583 Views
Last post by OldSchoolGuy
- 2022 Views
Last post by THEYTOOKMYTHUMB
- 459 Views
- 1166 Views
Last post by rcguy5
