fusion paint?
fusion paint?
Has anyone tried to use the Krylon Fusion paint on the white plastic chasis parts? What where the results/durability?
- Been thanked: 325 times
Re: fusion paint?
I've used Krylon Fusion black "paint" (it's actually more of a dye that bonds to plastic than a mere spray paint) on vinyl & hard plastic parts from my '70 Charger's interior that I'm in the process of restoring, and the results were excellent. It's meant to bond to the surface, not just paint a layer on top, and therefore resists scratching and dings.
I also used this black Fusion to "paint" a red Kydex bumper for my Zebra Optima, and I would say it's moderately durable. Keep in mind this is a bumper and I've run into a few things with it, and I can barely see some red underneath some areas that got some pretty decent scuffing.
With all that said, I would suggest using nylon clothing dye in boiling water as a better method of coloring nylon & plastic parts (i.e. RIT dye) but that Fusion-For-Plastic is very durable when applied properly.
- Diggley
Re: fusion paint?
Fusion's worked great on a couple projects
...So far used on both Lexan & Tamiya plastic:
Son's:
http://www.rc10talk.com/viewtopic.php?f=30&t=10823&hilit=warthog
Mine:
http://www.rc10talk.com/viewtopic.php?f=30&t=8967
http://www.rc10talk.com/viewtopic.php?f=33&t=12952
Son's:
Mine:
Projects and shelfers:
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: fusion paint?
Wow, I missed those threads until now(I need to get out more). Good stuff.Diggley wrote:Fusion's worked great on a couple projects![]()
Son's:
Mine:
Re: fusion paint?
The Krylon Fusion paint does work pretty well on most "R/C" plastics. About the only type I have found it to not work well on so far was the body that came on my Tamiya repro Holiday Buggy. I think it is some type of ABS or something but it's not the normal white styrene that Tamiya usually produces. This body came molded in dark blue and does not accept any type of paint even when scuffed and prepped properly.
- 78 Replies
- 9969 Views
- 1344 Views
Last post by Jedi Master
- 463 Views
Last post by THUNDERSTRIKE1
- 2926 Views
Last post by reign79
- 1384 Views
Last post by THE H.P FREAK
- 45 Replies
- 6610 Views
Last post by Synergy
- 2942 Views
Last post by JosephS
- 838 Views
Last post by MarkyDents
