The NXT Explode has a few errors
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Post by mytimac »
Doing more work on compatibility and found a few errors or inconsistencies in the NXT explode.
The transmission section is a mess. I have to get my hand on a manual and make changes to the explode for this truck.
Lists a3060 XX Slipper Shaft Spacer and Hardware. But in explode it references the same as a GTX, a3086.
Lists a3075 XX Upper gear, idler, shaft 2.19:1. A3075 is not in explode at all, but a3077 XX Upper gear, idler, shaft 2.61:1 is listed and in the explode.
Who knows what is right and wrong on this part. Since it uses the double pad slipper it could be using the XX shaft I suppose.
In explode there is a3088, which is a spacer on the shaft. But it is not in the list at all.
But there is listed a3087 and labelled Slipper Shaft Spacer. But a3087 is actually the idler gear.
Pretty sure this means they forgot to list a3088 and put its description on a3087 by mistake.
vwjuice
Re: The NXT Explode has a few errors
Post by vwjuice »
They changed very few things from the gtx. The transmission was left unchanged if I remember correctly. I have a gtx manual. If you want it let me know.
YZ-10
Post by YZ-10 »
Jedi Master thinks he has the NXT manual was speaking to him on MSN last night about it :wink:
mytimac
Business Member
Post by mytimac »
Thanks for offers, I have one or two NXT manuals coming my way soon.
I could use a copy of the GTX manual though.
Return to “Losi Forum”
Users browsing this forum: No User AvatarGoogle Adsense [Bot] and 3 guests
