Anyone know the longest shock shaft that will work on an original gold front RC10 shock?
Part #?
Thanks
Gold shock shaft question
- CamplinP
Re: Gold shock shaft question
In theory any shaft will work to connect two points. The travel will be the same regardless of what shaft is used. You can put a 1.xx" shaft in a .56 shock but you of course will get the same travel as a .56 shaft. I don't know if this is on point with your question. If the diameter of the shaft is the same it will work. I don't know any #'s off hand, I can check later.
- SMOKE-DOG
I ask because I want to use the top mounting hole on a Hot trick tower but I need a longer shaft. I wanted to know the longest shaft that will work on the front shock without problems. I remember seeing an article where they replaced the stock shaft for a longer one for more travel. (I think, can't really remember what they were trying to accomplish in that article)
TC showroom: http://tamiyaclub.com/showroom.asp?id=18447
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
- 974 Views
- 1387 Views
Last post by DMAT
- 1110 Views
Last post by Phin
- 897 Views
Last post by askbob
- 306 Views
- 708 Views
- 1491 Views
Last post by rcz
- 853 Views
Last post by Eau Rouge
Users browsing this forum: Mojeek [Bot] and 5 guests
