Sloppy steering- b4.1
Forum rules
b4.1 rtr. How much slop in the steering is "normal"? I have been through and tightened everything but there is slop in all parts of the front end. It seems excessive to me. What are some ways to reduce this? Shims, better servo, etc.. Thanks,
- Charlie don't surf
- Has thanked: 365 times
- Been thanked: 478 times
Re: Sloppy steering- b4.1
Lots of slop is "normal" and expect more as you run it- the only fix that I was happy with was to replace the steering kit/arms/rack with the older B4/T4 graphite composite set. The downside is that it is more prone to breakage if you snag a pipe-
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
... and it isn't even quicker on the trackCharlie don't surf wrote:Lots of slop is "normal" and expect more as you run it- the only fix that I was happy with was to replace the steering kit/arms/rack with the older B4/T4 graphite composite set. The downside is that it is more prone to breakage if you snag a pipe-
The B4.1 plastics are considerably sloppier than the B4's... my FT B4.1 looks like it's 5 years old after 5 races (winter indoor race series=, whereas my B4 was more solid after the same kind of treatment.
Frankly, don't sweat it, just run it as is. Sloppier cars are a bit easier to drive for us mere mortals
Paul
X3
Sometimes if you remove too much slop, it can make the car more difficult to drive. I've experienced that on both onroad and offroad cars.
If i have excessive slop, I try replacing parts that may be worn out before/rather than adding shims. (hinge pin bushings, ball cups etc)
X4
i use the plastic chassis on my factory team graphite b4 for just that reason. (i think the pros did too)
i do have the firmer steering though.
- 1405 Views
Last post by RC10th
- 1361 Views
Last post by yellowdatsun
- 920 Views
Last post by juicedcoupe
- 760 Views
Last post by mikea96
- 1163 Views
Last post by woodall01
- 1721 Views
Last post by Bugle
- 807 Views
Last post by slvrback
- 1505 Views
Users browsing this forum: Google Feedfetcher and 3 guests
