Hex adapters?
Hex adapters?
I was wondering if anyone knows where I can get some 17mm Hex adapters that will fit the rear axle(3/16"?) of Rc10t. It seems everything on ebay doesn't look like they will fit properly..to my untrained eye anywhays. Any help would be appreciated. Thanks
- PBR Allstar
- Has thanked: 36 times
- Been thanked: 1318 times
I just made a pair of 12mm hex hubs to adapt the 1/4 axles to Tamiya's wheels. I use the plastic hubs from Tamiya and widen the pin sides with a 1/4 ball grinder on a had drill at slow speed. Grind till the pin sit nicely on the hubs. Thereafter, I glue these hubs on a 3mm acrylic sheet and saw them off. This will give you a offset of 8-8.5mm as most hubs are 5-5.5mm thick only. You also need to sand 1-1.5mm off a the wings of your hub carriers. It fit nicely with near to correct offset. I'm currently using the front and rear wheels of Tamiya's Desert Gator on my gold tub runner.
- 972 Views
- 608 Views
Last post by civilguy
- 1208 Views
Last post by clhuke64
- 1412 Views
Last post by mikea96
- 19 Replies
- 1911 Views
Last post by rc10johnny
- 1827 Views
Last post by b027
- 1251 Views
Last post by Mr. ED
- 1446 Views
Last post by perry
