Hi-cap dampers.
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
Hi-cap dampers.
Hi,
I am nearing the end of my Egress build and I need some plastic bits for my Hi-caps. Does anyone know if this will work?
http://cgi.ebay.ca/Tamiya-53075-Hi-Cap-Damper-Mini-Plastic-Parts-Set-/390240971377?pt=Radio_Control_Parts_Accessories&hash=item5adc2caa71
Cheers
Cheers
Re: Hi-cap dampers.
i don't think so. those are for mini (mo3) shocks and i think the parts are a different size.
got a pic of the egress shocks?
Re: Hi-cap dampers.
thats what i though they looked like, nope that stuff won't work.
your shocks are wider if i recall correctly.
- 8rad
Re: Hi-cap dampers.
I am beginning to understand why the Egress sells for so much. Parts are IMPOSSIBLE to find!
The hunt continues!
The hunt continues!
- 8rad
Re: Hi-cap dampers.
Cool. Thanks.
Should be all sorted now. Got my steering, got my shock parts. Now I just need those darn BF9's and some decals.
Cheers
Cheers
- 8rad
Re: Hi-cap dampers.
Good ideas. I am not going for original so I am open to using different parts.
I may have a line on some BF9's and if it pans out I will share my source.
Still considering just making a pair but it seem a lot of work to get it right. There is not a lot of room to work in that front end.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Hi-cap dampers.
Jeremy
if not done yet - check that blog out.
http://tamiyaegress.com/?page_id=2
I think the bladder Q has an answer there
paul
paul
- 8rad
Re: Hi-cap dampers.
Thanks Paul. I meant the shock shaft seals. I should have been more clear. Yes, I have seen that blog. Its an awesome source.
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
- 8rad
Re: Hi-cap dampers.
It OK. I think my seals are fine. I noticed that two of the caps have air holes at the top and the other two dont. I had one of each on my front shocks so one was stiffer than the other. I though it was a shaft/seal problem but it should be OK now thanks.
- 1377 Views
Last post by minichamps11
- 927 Views
Last post by 8rad
- 2876 Views
Last post by Mr. ED
- 1679 Views
Last post by MelvinsArmy
- 865 Views
Last post by dsmith
- 24 Replies
- 3177 Views
Last post by kaszal
- 1605 Views
Last post by RC10Eh
- 1228 Views
Last post by Andyb78
