Vintage Motor Question/Help
mrlexan
Post by mrlexan »
Does anyone have the knowledge, know how, and parts to make this classic whole again? I would like at the minimum the correct end bell, don't really care if it as the correct arm. Let me know. The can is just too cool to simply toss. Thanks, any help would be appreciated.
Jay
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
You could "toss" it my way... :D That would look awesome in my Delta.
Doug probably knows what endbell to use, though...
The can looks Kyosho-ish.
wyldbill
Post by wyldbill »
it is probably a three piece can motor similar to an old checkpoint motor. 3 piece meaning the bottom is machined aluminum,the can separate and probably aluminum enbell to i would hold on to it and doug probably will be able to tell you more.
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
It's a rebadged Kyosho can.
To put it together you want to find a Kyosho Le Mans 240S motor. It's a 19 turn single wind and the endbells are colour coded with the mounting plate.
Eau Rouge
Post by Eau Rouge »
terry.sc wrote:It's a rebadged Kyosho can.
We have a winner! :D
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
I have that endbell and the roter too.
The endbell is red plastic with chromed metalware: got it in front of me.
Let me know if you want it.
The roter I can't send you: I know I have it , but I got no clue which one it is :lol:
The moter I had never worked well for some reason and I parted it out.
mrlexan
Post by mrlexan »
Is the endbell new or used? Thanks Erik.
Mr. ED
Post by Mr. ED »
It's been prepared to use: original leads replaced (should still have them) and capacitors mounted. Tested, didn't work very well, replaced brushes, same, given up upon.
I can make a picture if you want.
mrlexan
Post by mrlexan »
Please do, I will be traveling tomorrow so I don't know when I can get back to you.
carloco8
Has thanked: 74 times
Been thanked: 271 times
Post by carloco8 »
mrlexan wrote:Please do, I will be traveling tomorrow so I don't know when I can get back to you.
When you come down to LA, try to not clean out my local hobby shops of the old stuff you find ........j/k :D
Seriously though, have a safe and fun trip in sunny so cal.
Mr. ED
Post by Mr. ED »
Here you go Jay
