Anodizing Yoke magnesium parts
- Seabass
- Business Member
- Been thanked: 12 times
I have searched and come up with nothing for anodizing the magnesium parts on these cars. Anyone know if it can be done without destroying the parts?
If no one knows, I will report back when I attempt it.
Jake
Jake
- Been thanked: 498 times
Re: Anodizing Yoke magnesium parts
As far as I understand, magnesium doesn't anodize. there are specialized coatings that magnesium parts are subjected to when used in military applications, like alodine(sp?) or something like that.
I would worry that the anodizing bath will cause major shape degradation of the parts, especially tapped holes.
- Seabass
- Business Member
I looked back at the Kyosho forum beacuse Jay Dub had some Optima kunckles anodized which he said they came out greyish.
Were the Optima parts magnesium, I thought they were?
I really need to get this figured out.
Thanks for the help.
- ROH73
- Been thanked: 22 times
Magnesium can be anodized. The coating is not as durable as aluminum's, so the resultant oxidized surface is usually just used as a primer for further coating or painting. Also, there is no dying involved, so you end up with a tan/brownish color to a green. It's not very attractive.
The Optima parts are aluminum; I don't recall Kyosho using magnesium for anything.
- Seabass
- Business Member
Well crap.
Thank you for the info. I was certain the Optimas knuckles were magnesium because they look so similar to the Yoke parts.
Well I guess I need to find a rear aluminum bulkhead and an aluminum motor plate.
Thanks for the info.
Jake
Jake
The Kyosho steering knuckles are aluminum. The cast versions dont't anodize well. And I don't think the magnesium parts will "anodise". It is merely a conversion coating to prep it for another type of coating (like stated before). You could paint them, after some type of conversion coating. Speak with your local plater for options. -Jeff
- 2731 Views
Last post by rctodd1624
- 549 Views
Last post by Toaster
- 746 Views
Last post by vintage AE
- 2066 Views
Last post by Brandon G
- 2890 Views
Last post by NRG
- 1903 Views
Last post by Boss155
- 1221 Views
Last post by clinehobbies
- 2441 Views
Last post by badhoopty
