acceptable outside temperature
- Has thanked: 4 times
At what temperature would people consider optimum for running cars/trucks outdoors. I had one of my non-vintage trucks out today and took a fairly tame tumble cracking a bulkhead. It is lower 40's where I live and that is probably a bit to low to run anything without the plastic turning to brittle. I know the answer to the question is more opinion than fact based.
Re: acceptable outside temperature
i had my gt out today, it was probably around 40 degrees out. only problem i had was that one of the screws holding my arms on came out. might have just been stripped from getting old, but i didnt have any other troubles. i beat it pretty hard, runnin full blast in a parkin lot jumpin it off big ol' snow drifts. it also has rpm arms front and rear, so stock plastic may have broken, but the rpm arms held up great...
Raised on cornfields.... Killing on Paintball fields... Nebraska Baller Through and Through
- 1643 Views
- 1870 Views
Last post by azone
Users browsing this forum: Google Adsense [Bot] and 4 guests
